Old 12-02-2006, 02:35 PM
boilerman's Avatar
SFT Brewmaster
Default Making of a Rose
well to start off here we will go out to the scrap pile and select some fine scrap ....we need enough sheet (22 or 24 ga) to make
"1"square at 3 1/2
"3"square at 4 1/2
"2" square at 5 1/2
and about 12" of 1/4" rod and 12" of 3/16 rod
and refreshments
ID:	17961   Click image for larger version
Old 12-02-2006, 02:42 PM
boilerman's Avatar
SFT Brewmaster
ok now take all squares EXCEPT FOR ONE OF THE 4 1/2 and lay out your petals and cut them out with the remaining 4 1/2 you will make and cut out a star....after you got everything cut and cleaned up drill a 1/4" hole on center....the pieces that come off the star square you can make your leaves out of
ID:	17967   Click image for larger version
Old 12-02-2006, 02:48 PM
Bender's Avatar
Bender Bender is offline
One Lone Sub
Hold on... Lemme go to the scrap pile.
Ahh ok
ID:	17970   Click image for larger version
Boise Paint Contractor
Facebook
How fortunate we are!
Old 12-02-2006, 02:49 PM
boilerman's Avatar
SFT Brewmaster
if you have followed instruction you should have a pile of parts that look some what like this
Old 12-02-2006, 02:54 PM
boilerman's Avatar
SFT Brewmaster
now grab your 1/4 rod and we are going to texture it ....oh hell well are going to beat the $hit out of it to give it a natural look....do the same with the star if you fine a rough surface it works better
ID:	17972   Click image for larger version
Old 12-02-2006, 02:55 PM
Ahh ok
Now that's my kinda scrap pile...
Old 12-02-2006, 03:05 PM
boilerman's Avatar
SFT Brewmaster
now we need to "cup" the petals ....good size washer and a ball peen works good here ....when all done you parts should look like the last pic and we are ready to start to put this thing together
ID:	17974   Click image for larger version
ID:	17975   Click image for larger version
Old 12-02-2006, 03:14 PM
boilerman's Avatar
SFT Brewmaster
grab your 1/4" rod (not the one god gave you, the one that came out of scrap pile) and clamp it up in the vice and silver solder or braze star on it ....then put petals on and drive them down with a pipe nipple and mushroom over the stem to make everything together
ID:	17977   Click image for larger version
Name:	pedals attached.JPG
ID:	17978   Click image for larger version
ID:	17979   Click image for larger version
Old 12-02-2006, 03:20 PM
keenavv keenavv is offline
If you drank that Arrogant ******* Ale you'll have a serious BITTER BEER face!
Old 12-02-2006, 03:23 PM
boilerman's Avatar
SFT Brewmaster
truth be known i had a double ******* ale before i started this ....have to check everything tomorow morning cuz i'm pretty wasted right now
