Old 04-08-2006, 01:02 AM
X-ray's Avatar
X-ray X-ray is offline
Default Pull-down band-saws
The intent of this thread is to do what I can to help a fellow SFT'r who happens to use the same saw (Kama EV 996) by passing on what experiences I have gathered about the saw.
And if a discussion occurs, then it might serve also as information for others that may be looking into the pull-down style of band saws. Advertising promotional for a pull down type bandsaw
Sure the advertising claims the Kama as "the worlds most accurate band saw", this I would chalk up to advertising hyperbole. That is to say I did not get dead-nutz accuracy out've the box...it took alittle work
If you are finding your cuts off by an unacceptable amount start with following checklist:
1) material crooked or clamped crooked in vise
2) blade condition
3) turning lever not tightened
4) turning support not flush with stops
5) stops out've alignment
6) sliding blade guide support, not adjusted to size for cut
7) sliding blade guide support lever not tightened
8) too much or too little feed rate or pressure
A pull-down bandsaw's feed rate is done manually, and for each material type and shape there is an optimum pull force- things will get better with 'trigger' time.
For me it has been forcing myself to slow down or lessen the down force I apply to the bow. Looking at the chips and listening to the sounds during the cut have been the most help in judging the pressure required. Sometimes seeing the chips while cutting is not the easiest because they get washed off by the coolant flow.
Name:	zero degree stop.JPG
ID:	11554   Click image for larger version
Name:	baby combo square to true vise to blade.JPG
ID:	11555   Click image for larger version
Name:	5-8 tpi blade setting up to cut a test section.JPG
ID:	11556   Click image for larger version
Name:	first cut finished.JPG
ID:	11557   Click image for larger version
Name:	sectioned piece on reference surface.JPG
Does anything happen to me? I take what comes... -Marcus Aurelius
Old 04-08-2006, 08:05 AM
Team DeSade's Avatar
Team DeSade Team DeSade is offline
Send a message via AIM to Team DeSade
Good info there X-ray. Hopefully it won't be too long before I can buy one and look this thread up to get it cuttin' straight.
Just to make sure this gets found in future searches, I'm adding in the words horizontal bandsaw as a common synonym.
Terry
Old 04-08-2006, 10:12 AM
Cavalry's Avatar
Cavalry Cavalry is offline
Below Wholesale
ok someone educate me.... I read that article above. I guess I dont understand why you would want a pull down over a hyd feed saw? There will be times at work I will sit at the saw all day. I cant imagine if I was feeding it for 8 hours!!
given my saw is a ancient K-zoo and is inaccurate as all hell. by watchign the chips and listening to it I can judge the best feed speed for the material.
I guess my question is why dont they make an accurate saw like the above with a full power feed? I see there is a gravity assist option on some?
Old 04-08-2006, 11:32 AM
JT Metalworks's Avatar
JT Metalworks JT Metalworks is offline
Banned
These are being used like a chop saw would traditionally function. There's no need to fine tune a cylinder's adjustment if you're only making 3 cuts. Transitioning from some aluminum extrusion (pull `er down fast) and some wide flange I (slow and steady) is a matter of putting the stock on the table and clamping it.
They're in the same category as the cold and dry cut saws are being marketed in - only they have the distinct advantage of larger capacity for the same floor space, and much cheaper consumables (blades). The larger capacity is the trade off for not being as fast as the circular saws.
If you were doing a lot of large stock, then you wouldn't likely be looking at something this small. There's another saw of this size called the Acrobat that's fully automatic as well though - I think X-ray also posted a link to it.
Old 04-08-2006, 11:59 AM
KB Fabrications
Guest
Posts: n/a
Ray,
While I don't have a saw like that, I think you did a nice job with this post. Those saws are nice units and wouldn't be around if there wasn't a market for them. Your post will be valuable info for someone who has the saw or is looking to get one.
Old 04-08-2006, 12:59 PM
X-ray's Avatar
More pics, but got to split for daughters soccer game- somebody fill in the commentary.
good job starting bs session guys, talk with you later
Name:	cut one using spacer under.JPG
ID:	11579   Click image for larger version
Name:	sliding blade guide.JPG
ID:	11580   Click image for larger version
ID:	11581   Click image for larger version
Name:	3rd cut now we can make some hay.JPG
ID:	11582   Click image for larger version
Name:	3rd cut finished.JPG
Old 04-08-2006, 01:05 PM
Good show, X-ray. I have installed this link in the project index forum.
Old 04-08-2006, 01:44 PM
Banned
These guys make the Acrobat, even though it's not listed in their line-up yet.
http://www.pilous.cz/english/pas_pily_e.htm
Old 04-08-2006, 02:49 PM
X-ray's Avatar
Random pictures. One is the 0° stop with the hex jam nut backed off from the turning support. This allows the user to set the stop bolt stick-out.
The previous series of pictures, showed the process I used to take two 4' x 6" pieces of aluminum and turn them into 6" x 2" weld practice material. The 6" wide strips were sheared at the supplier from a 4' wide sheet. The sheared edge is not as straight as the factory edge, so inaccuracy was already in the material before it reached my saw. One could use the cutting method in the '1st cut' to minimize this.
Name:	stop hex jam nut.JPG
ID:	11614   Click image for larger version
Name:	chips note part position.JPG
ID:	11615   Click image for larger version
Name:	cut face 8 pieces equaling 1 inch wide.JPG
ID:	11616   Click image for larger version
Name:	eight two inch wide pieces minimal burr.JPG
ID:	11618   Click image for larger version
Name:	sliding blade guide adjusted for cut.JPG
Old 04-11-2006, 10:24 AM
pagoda pagoda is offline
well i am one of the other 996 owners on the group. check out the problem i am having. (see photo) BTW, this saw is a used saw from the dealer, so i am working on getting a new one. i will post some photos later tho show how far it is "out"
maxstar 150 stl
kama ev996
diacro#2 bender
diacro#3 bender
RMD100 bender
HABERLE cold saw
millermatic passport
TA185
full wood shop...
