Old 03-22-2006, 08:04 PM
gmc1999's Avatar
gmc1999 gmc1999 is offline
I Messed With Texas
Default Clarke grinder
4-1/2 IN. VARIABLE SPEED ANGLE GRINDER
$34.98
Powerful and lightweight - designed for use in almost any cutting or grinding job
No load speed 0-11,000 RPM
120 volt/60 hz, 8 amp., 1.3 H.P.
Electronic variable speed control
Comfortable trigger grip with lock ON switch
Removable three position handle
Spindle lock for easy accessory changes
Includes 4-1/2 in. grinding disc
Anyone have opinions of this model?
Thanks Bill.............
Old 03-22-2006, 08:34 PM
Tom Zachman's Avatar
Dodge City Marshal
I like the Clarke junk I own. Haven't heard any good reports on their wire welders. I have the 110 volt stick welder and get what I expect from it, which is not much...
New sig line:
Old 03-23-2006, 11:17 AM
SlagKing's Avatar
SlagKing SlagKing is offline
A Man for All Reasons
Tom:
I'll give ya a report on wire welders.
I have two Clarke's
180 and 95.
I use the 180 several times a day, mostly fluxcore, and it's a nice little welder.
Two years so far and never, ever, one bit of trouble. I have yet to use max settings, although on thicker welds, I do use stick.
A couple times I have welded the other white metal of horse trailers and there it has done good work. Feeding .030 white metal at first was a little tricky, but after I set things up correctly, nice and smooth.
The 95 works good and it is fluxcore only. I use it for field work on railings/railing repair. On tubing it will lay enough weld, but the duty cycle is very short. I have hit it several times on fairly short welds, but it, like the 180 has never ever caused trouble or stopped working.
I have never hit shutdown/duty, on the 180, sometimes welding pretty much straight for hours at a time. Again, I don't weld near max settings with it, but I like how it does what it does.
I have used Millers at my nephews welding shop, and when set at near the same settings, I can't tell much difference between the Millers and my Clarke 180.
There you go Tom, as somewhat requested.
Mystic Seer, Pat.Pending Director of Pillage and Rymed Whimsery
Sir Slag the Seer
Old 03-23-2006, 11:27 AM
SlagKing's Avatar
I would like to add.....
I have welded with a Miller 130. It was better then my Clarke 95 but I don't think it's much better, if at all , to a Clarke 130.
I like the Clarke 130 much more then my Clarke 95. A little more power, a cooling fan, and higher duty.
I plan on replacing my 95 with a 130 for the reasons stated.
The Miller 130 has the auto feed speed thingy and I found that somewhat different. Yeah it welded okay, but not as consistent as a standard tap type welder.
Okay I'm done.
Sir Slag the Seer
Old 03-23-2006, 07:56 PM
Dodge City Marshal
Thanks Slag...
New sig line:
Old 03-23-2006, 09:06 PM
7018's Avatar
7018 7018 is offline
I had to get a small grinder fast so I picked one at Wal-Mart it was used hard and it still runs..Its been over a year now...
This post brought to you by the bringer of chaos, doom, change, and technology... Asker of questions, challenger of assumptions, solver of problems and share-er of ideas
