Old 01-09-2006, 06:22 PM
X-ray's Avatar
X-ray X-ray is offline
Default Cold Lap
For those interested in such things, here are a couple of attachments showing decent cold lap on the toes.
The welds were short, just to attach a nut and vert down.
.035 wire
320 wfs
20 V
Pretty sure too much volts primary causative (ooh big word, hope I used it correctly) agent.
Name:	Cold lap toe.JPG
ID:	8824   Click image for larger version
Name:	cold lap toe other side.JPG
Old 01-09-2006, 06:26 PM
texrednek's Avatar
texrednek texrednek is offline
Still on Ritalin
Send a message via Yahoo to texrednek
down with the cold lap lol.....we dont need no stinkin cold lap
CHRIS
IF IT CATCHES...Let it burn
Old 01-21-2006, 10:09 PM
Engloid Engloid is offline
I would call that Lack of Fusion.
Why? Because nothing lapped...it just layed on top of the base metal without making fusion.
Old 01-21-2006, 10:31 PM
hobby_welder71's Avatar
hobby_welder71 hobby_welder71 is offline
Send a message via MSN to hobby_welder71 Send a message via Yahoo to hobby_welder71
looks like some people i know and they dont like it when i come to inspect there "welds" one has to reweld allmost every frame at least one outrigger for that kind of weld
Old 02-03-2006, 08:09 PM
Have you suggested that the guy turn his wirespeed down or turn the heat up?
Old 02-04-2006, 12:10 AM
X-ray's Avatar
FWIW, If I could only change machine settings here and nothing else, Voltage would have been turned down.
The toes look like they do because the arc length was too long. The easiest thing that I could have done would have been to hold a closer ESO by moving the nozzel closer to the joint.
Does anything happen to me? I take what comes... -Marcus Aurelius
Old 02-04-2006, 12:26 AM
i think he is doing the same as x ray said he cant see what he is welding and worries about anouther weldor getting ahead of him so he trys to rush when he needs to just slow down and take his time ive try to tell him if he makes a good looking weld that look burned in that when the hud, itc, and other inspectors come in that he would not have to worry about getting the write up and will not have to hear any thing from me
Old 02-04-2006, 08:44 AM
I'll disagree. This problem is caused by melting the wire, but not the base metal. This is because there's not enough heat input to melt the base metal. Slowing down puts more heat in the base metal, but would also mean a higher deposition rate. That's why I suggest less wire...cause you then can slow down and keep the same size weld. Or, more voltage.
If this problem was caused by having the arc length too long, you would have gotten undercut at the sides of the weld.
Go to the guys welding machine after he leaves one day, turn down the wire speed, and see what happens. I'm sure you will have to travel a little slower, but the weld will improve. The better option would be to turn up the heat, as this will allow travel speed to stay up.
