Old 12-17-2005, 11:41 PM
digr digr is online now
Default Plans for a self cleaning bench
Pull one lever and stand back and watch your bench clean it self. You MUST stand to the side before pulling lever!!!!
Name:	CLEANING BENCH.jpg
Old 12-17-2005, 11:59 PM
bgott bgott is offline
Trailers for sale or rent
What CAD program are you using to draw this stuff? Pretty neat, I say!
Old 12-18-2005, 01:21 AM
Bgott The program is called "Smartdraw". It is not a true cad like solidworks or artocad but its fast and fairly easy to run. It is a share ware program that you can download to try it. If you do let me know and I can send you some drawings to play with. The drawing that I make are not to scale but I can come close.
Old 12-18-2005, 04:03 AM
Digr, I downloaded SmartDraw shortly after I refurbished this computer; all I could find was a 30 day trial version that I have not found time to even try to learn & I think it is about to expire. The software is $200.
So I have to guess you found a different deal than I did.
Old 12-18-2005, 08:56 AM
rickairmedic's Avatar
SFT HVAC Guru
Digr the self cleaning bench is a good idea but now we need plans for a self cleaning floor .
Rick
Old 12-18-2005, 09:57 AM
s_ontario
Guest
Posts: n/a
Anyway you could put a Hydraulic Cylinder on that so we wouldn't have to pull on a lever ? with push button control
Old 12-18-2005, 10:10 AM
I was thinking of going hydraulic but I think it would be to slow, everything would land in front of the bench but with the springs it would throw everything across the shop so you could still walk in front of the bench
Old 12-18-2005, 03:52 PM
Wrenchbender's Avatar
Wrenchbender Wrenchbender is offline
Mender of the Yellow Iron
Location: Belton South Carolina Home of the Standpipe Festival
Hey I used to have a bench sorta like that.One of the legs wasn't attached very well and it would kick out at will Everything would slide over to that edge and fall in a pile.I like yours better all you need is magnets on the wall in front of it to catch the stuff it slings over.Then sort through the stiff that don't stick.
"Banking establishments are more dangerous than standing armies. Thomas Jefferson
Old 12-18-2005, 04:00 PM
jniolon jniolon is online now
digr,
are the images like the motor and valves... from a image file or did you draw them ???
john
...my truck project has turned into garage art !!
Old 12-18-2005, 04:11 PM
Originally Posted by jniolon
digr,
john
I drew them and keep them on file so I can use them when needed. A lot of them were for practice like the wrenches and screw drivers hack saw and such. but most of them I use in drawings like the valves motor ect.
