Old 11-24-2005, 04:34 PM
Default Nice little press
The bigger press is the one I built for our shop at work It is from 10" H beam pile drops. Actuality there is two presses the big cylinder is a 6" dia with a 24" stroke. The long stroke is nice because you don't have to move the table very often if ever. The Little one is a 3" cylinder with a 18" stroke. Each has a adjustable table and pusher plates. The small engine man likes the little press as it is hard to "feel" when to stop with the bigger ram when working with smaller bearings and such. There is a 5 HP motor with a 2 stage pump with a selector valve to run one press or the other.The press is about 8'X8'4'. The table for the bigger press has a 1 1/4" thick removable plate with 1 1/4" pusher plates. There is 36" between the uprights.The motor is a 5HP 1725 RPM running a northern tool two stage pump with the least GPM you can get [you don't need speed] running @ 3000# pressure giving the 6" cylinder about 40 tons and the smaller one about 10 ton.If building another one The only thing I would change would to make the smaller press using a 4" cylinder instead of the 3" because of the speed. Even using a flow regulator the 3" is little fast but nothing you can't get used to.
I was going to wait until I got it cleaned up and painted but its been 5 years so I don't think its going to happen.The next press is the one I built for home with a lot "smaller" budget. It is made out what ever I could scrounge. It started out to be a bench model but got to high so I had to build a separate base which actually worked out well. This press has a 4" cylinder with a 14" stroke. This started out as arbor press but it is mostly used as press break. It is 24 1/2" between the uprights which are 4"X6" H beam. The top has the same H beam plus 1/2" flat bar. With the dies and blade I made I can bend 24" of 1/8" plate to a 90. 4"X1/2" flat bar is not a problem. I also have a back stop for doing multiple bends. It sure came in handy when I made 30 shelf brackets. I have a car lift that I run of this press using quick coupler Things MUST be kept centered on press! It also has a 5 HP 3450 RPM motor running the same pump as the bigger press. If I were to build another one I would use a 6" cylinder. With a 6" cylinder you could bend at least 24" of 3/8" plate to a 90. I would not use a motor faster than 1725 RPM and not use flat bar for the top. It flexes a little at full pressure. I would use the A frame design like the bigger press. The 4" inch cylinder gives you about 18 ton. I have drawings if anyone wants them. They are without dimensions because it all depends on the size ram you start out with
ID:	7613   Click image for larger version
ID:	7614   Click image for larger version
ID:	7615   Click image for larger version
ID:	7616   Click image for larger version
Old 11-24-2005, 04:40 PM
Default small press
small press
ID:	7618   Click image for larger version
ID:	7619   Click image for larger version
ID:	7620   Click image for larger version
ID:	7621   Click image for larger version
Old 11-24-2005, 04:55 PM
Default projects
press projects
ID:	7623   Click image for larger version
ID:	7624   Click image for larger version
ID:	7625   Click image for larger version
ID:	7626   Click image for larger version
Old 11-24-2005, 07:48 PM
quadlinear's Avatar
quadlinear quadlinear is offline
Default press
Digr,
Wow, sure made some nice fabrications such as the bins and bracketry. Nice job of making the presses as well.
Alan
Quadlinear
corner of South West, Ohio
Old 11-24-2005, 09:15 PM
Wow digr, this stuff just blows me away.
Great thread; thanks for taking the time to post it.
Old 11-24-2005, 09:22 PM
RED caddy's Avatar
10-28-1951 to 4-19-2021
Da Chief
Default Nice stuff...
Gonna steal me some of those ideas, yup yup. RED
Old 11-24-2005, 09:47 PM
tackit's Avatar
tackit tackit is offline
One word....IMPRESSIVE! I like everything about the both of them digr, nice work thanks for the pictures and info on the hydraulics.
Old 11-28-2005, 06:23 PM
s_ontario
Guest
Posts: n/a
Nice press i could really go for something like that (smaller one i mean) or a mix's of the two
Will a 2Hp motor 1725 Rpm motor run a press like this and you would use a 4gpm pump ??def needs to be 2 stage pump ??
I have two 4 inch cylinders off a Backho back lift struts think they are 16" stroke - that should work hmmmmmmm
Whats 8" channel weight per foot ?
whats 4"x6" H beam weight per foot ?
ok guys find me a pump i have the rest
going to go to the scrap place tommorrow see what *cough* cheap steel he has
found this pump what do u think
3.2 GPM PUMP @ 1800 RPM .5 CU/IN
Image SAE A - 2 BOLT MT.; 3000 PSI
Image 5/8" KEYED SHAFT
Image #16 SAE INLET; #12 SAE OUTLET
$89.00
Old 11-28-2005, 10:23 PM
Wrenchbender's Avatar
Wrenchbender Wrenchbender is offline
Mender of the Yellow Iron
Location: Belton South Carolina Home of the Standpipe Festival
Great work ifin I was gradin ya it be an A+ but I ain't no teacher so I'll just say EXCELENT work!
"Banking establishments are more dangerous than standing armies. Thomas Jefferson
Old 12-18-2005, 08:16 PM
s_ontario
Guest
Posts: n/a
Digr : on your small press that you use as a brake The top die how much of a bevel edge did u put on it / and does it come to a real sharp edge ? and what thickness is the top die material
and i found another 5Hp motor on the farm that i wouldn't mind swaping to a 2Hp only thing is this 5Hp is 3400rpm ?
