Old 02-12-2020, 11:53 AM
Default Ramsey Worm Winch Modification
This winch is part of a different thread called “Quick Attach Dump Box” in the Fabrication forum. I thought it interesting enough to hold its own here.
The objective here is to make a narrower spool and install it in my existing Ramsey RE8000 winch. The result will be much like the one shown below. The winch is to be used to tip a dump trailer. A narrow spool will package better on the 3” mast that it will be mounted on.
Old 02-12-2020, 12:08 PM
Here I am turning one of the spool flanges. The part is being held to the jaws of the chuck by the axial force from the tailstock live center.
Old 02-12-2020, 12:21 PM
The chamfered ends of the hub and a gap created with welding rod both help to improve weld penetration and create a weld fillet.
Old 02-12-2020, 12:26 PM
To protect the rope, the weld is now being cut down to a somewhat smooth radius.
Old 02-12-2020, 12:32 PM
After cutting with a HSS tool.
Operations like this invite chatter. I mitigate the chatter by moving the tool from one side to the other in a series of little cuts.
Old 02-12-2020, 12:37 PM
Boring the center and cutting the dog clutch feature of the drive flange. Notice the opposite flange is not on yet.
Old 02-12-2020, 12:40 PM
Milling the dog clutch.
Old 02-12-2020, 12:46 PM
I saw an opportunity to provide a bit more integrity here by adding two plug welds even though I doubt that it was needed. The load path goes through this flange into the hub and then to the rope.
Old 02-12-2020, 12:54 PM
The rope attaching feature has been added to the hub and now the opposite fillet weld is to be cut.
Old 02-13-2020, 01:10 PM
Looking good!
Woodrow Wilson
