Old 12-27-2019, 06:12 AM
Default Pintle Hitch Tow Ring
I made this ring for the dump box trailer/pusher that I am making. I thought some would find the process in used to make this interesting.
I have (or had) a bending jig to form a ring like this but I cannot find it. Rather than make another jig and source steel rod that I did not have I decided to use a piece of 1” HR plate left over from another project.
Old 12-27-2019, 06:21 AM
After laying out the trim lines on the surface I used a hole saw to rough out the hole. A boring bar was then used to size the hole to 2.5”
Here I am using a 1/2” corner radius cutter to shape the inside of the hole. The cutter was secured in the boring head so one cutting edge made contact with the work.
Old 12-27-2019, 06:41 AM
The outside was cut using the same corner radius cutter. For this, the cutter was placed in the spindle as normally used. The Z height remained constant while I moved both X and Y axis as needed to make a series of cuts around the outside.
Covering the surface with layout dye helped provide contrast for this sight milling. Placement of a work light also proved to be very helpful. A light behind the cutter in the right spot made seeing the cutting depth easy. I was able to proceed without having to move the tool out of the way to check my progress.
Old 12-27-2019, 06:48 AM
Old 12-27-2019, 06:49 AM
Working around the ring moving the light as needed.
I have the quill completely raised on the machine. This eased the strain on my neck and back a bit.
Old 12-27-2019, 07:46 AM
Not shown in this picture is the layout dye that I added before I took the grinding disk to it. The dye here was not as helpful as when cutting on the mill but the cost was low.
Old 12-27-2019, 08:32 AM
The finished ring.
Old 12-27-2019, 08:50 AM
Well done!!!!
Old 12-27-2019, 09:23 AM
Yes, well done. More of a machining thread but heck, metal carving at it's finest. Are all the commercial pintle rings mild steel?
Old 12-27-2019, 10:14 AM
Just flipping the picture.
