SFT Search: |
Thread Tools | Display Modes |
![]() This welder showed up on my local FaceBook Marketplace a couple days ago. For $50 I figured it was worth taking a look at. And I was the "lucky" winner as in first to reply and show up with the money. It was only 5min from my house which was a large factor in me buying it. Paid the asking price and the welder and accessories shown were loaded into my trunk. I don't necessarily have a use for another 120v MIG welder--I have a MM140 that might get used once a month. But for the money I figured I could find a needy party that could benefit from it. The last little similar Craftsman I bought ($80) went to a buddy of mine that had done me numbers of favors. Who should this one go to? ![]() ![]() Pics are "after" cleanup and testing. I had to adjust the liner and lube and loosen the idler bearing because the welder had been sitting a while. That is a Tweco handle and tips. It has fluxcore in it and once cleaned and detailed, produced the weld shown. (con't)
Before you go thinking that the air pressure at the roof of my mouth is less than atmospheric, consider that the pic #6 shows the condition of the inside of the unit BEFORE I worked my magic. Inside the wire cover and on top were similar!
![]() I've included a compatible owner's manual downloaded from manualslib.com.
Hot torch or cold torch ?
Cold and I verified because I had the same concern...
My neighbor saw it and is interested--might not be a Christmas gift after all... ![]()
IF I Recall Correctly.
When Lincoln Acquired Century welders "Lincoln" Made that piece of shit using the Century name That pretty much killed the Century name. Notice the shiny plate with the circuit board see the rivets, IIRC there is eight MOFITS one held by each rivet. Most of the time when one goes bad it takes out the others and the machine is pretty much junk. The Tweco gun should be good for $100. Likely Lincoln will have the manual.
* * The factory of the future will have only two employees, a man and a dog. The man will be there to feed the dog. The dog will be there to keep the man from touching the equipment. ~Warren G. Bennis Last edited by GWIZ; 11-23-2019 at 10:03 PM. |
Something like this but you have to go by the model number on the back.
https://www.centurytool.net/117_078_...old_s/1809.htm
I wonder how the welds would look if you use a helmet....
![]() I thought that was what eyelids were for? ![]()
TA Arcmaster 185 w/tig/stick kit MillerMatic 252 w/3rd gen 30A MM140 w/o AS, w/CO2 Hobart (Miller) 625 plasma Hobart 250ci plasma Victor O/A (always ready, but bored) HF 80 lunchbox w/tig 45ACP Black Talons for those stubborn jobs... Last edited by mccutter; 11-25-2019 at 11:05 PM. |
That welder is a rebranded Cetury 155GS. They are 105 amps. The drive roller should be knurled so it will never wear out. They have variable voltage but the gun is hardwired in. My guess was it was aimed at being a cheaper alternative then a miller. Lincolns tend to be pricey and have a low duty cycle. I have a 155GS and it has not had a problem for over 20 years. I paid slightly under $400 for it new. I think Century discontinued that model before they were bought out.
Welcome to the site.
Somewhere I read that the knurled groove is for Flux wire so you use lighter pressure, as not to crushing the wire.
