Old 02-27-2019, 12:43 PM
Default Need to taper aluminum bar
I need to put a taper on some inch and a half round aluminum bar. I do not have a taper attachment for my lathe. Is there another way to do this? Seemed to me I had read someplace in the past about moving the tailstock off to the side. The taper needs to be roughly a quarter inch over 18 in.
Old 02-27-2019, 12:55 PM
Yes you run between the two centers and offset the tail-stock.
Old 02-27-2019, 01:21 PM
Right now I cant remember the details or if Bell is the right name, I believe on a large offset you should use a bell type center drill and not a "standard C drill", something about clearing the point of the center when at an offset angle.
Somewhere I have some Bell center drills but never used them.
Old 02-27-2019, 03:11 PM
You should be able to get it with the tail stock off set. I have made a cup shaped center for the tail stock and used a ball bearing for the center when cutting a taper.
Old 02-27-2019, 03:33 PM
Yeah, 1/4" isn't a lot of offset. Like Digr says use a fairly large centre drill to make a decent sized pocket in the end of the workpiece and then use a ball in the tailstock. Use a blank end arbour with a matching hole in it and put a small bearing ball between the arbour and the workpiece and you're good to go.
The other option is to make a relatively small hole in the workpiece and then use a live centre--this is probably easier than using a ball and if you keep the hole in the workpiece quite small the centre will tolerate quite a bit of offset. Considering what we've seen you do I suspect this part will be mostly decorative in nature and tolerances won't be too tight....
Old 03-07-2019, 09:09 AM
Appreciate all the advice. The job has been changed from aluminum to SS, no more taper, and only a slight offset on one end. Should be a bit easier.
