Old 08-06-2005, 06:42 PM
boilerman's Avatar
SFT Brewmaster
Default sand blaster
was just getting ready to start making one of these out of an 20# propane tank...working pressure will not exceed 100#.....anyone have thoughts on this
http://www.northerntool.com/webapp/w...ctId=583&R=583
will hydro it to 250lbs when done
Old 08-06-2005, 08:00 PM
Thumbs down
umm hmmm, I have one. I'm so proud of it that I leave it out in the rain.
The only piece of it that is worth throwing away is the tank. The "gun" is the worst piece of junk to be billed as a "working tool" that I have ever seen, bar none. It uses a spring loaded roller to squeeze against a rubber tube as a valve. The threads on all of the parts are neither ASE or metric, as best I can tell. And the media gates are just junky ball-type shutoffs so they either jam half open or half shut about 50% of the time. If you want to build a knock-off that will work Boilerman, I recommend that you drop by HF & study that one as your example of precisely what NOT to do, then proceed in the opposite direction for every single component except possibly the tank. Even the paint sucks.
I bought mine to sandblast that old Delta bandsaw I restored 2 or 3 years ago and I fought it for the better part of a week. Then I picked up a little siphon-bucket type at a salvage store to finish the job. It is a far superior tool.
Old 08-06-2005, 08:12 PM
7018's Avatar
7018 7018 is offline
boilerman I built mine out of a propane tank,i used a 3/4 S.S.ball valve on the end of the blast hose.The tips I get a NAPA 3/32 out let whole.I used 1/2 air hose for the blast hose.The main thing you have to remember is to screen your sand,even the finest blasting sand will plug up the tip if you don't.Another good idea is to have a 3/32 welding rod with the flux knocked off to run into the tip when it plugs up....I've done alot of blasting with the little pot it works great....If you want I'll get some pics tomarrow nite and post them...But like cutter i leave mine out side not because I don't like it.just because....... I've got a job to do tomarrow so it will be in the evening if you want them.....
This post brought to you by the bringer of chaos, doom, change, and technology... Asker of questions, challenger of assumptions, solver of problems and share-er of ideas
Old 08-06-2005, 08:22 PM
boilerman's Avatar
SFT Brewmaster
ok...score is tied 1 to 1....this will be made out of stuff i have ....yes i'm cheap and refuse to spend money , so with that said the nozzle will be pipe ...more than likely it will be 1/4 or 1/8 pipe nipple....the reason i think i need this ,beside the reason that a guy has have to have stuff is ...i noticed a bubble on the bed of my truck right above the rear tire ....so i figured i'll just wire wheel that and slap some paint on it ....well when i got done wire wheeling it i got a hole that i can put both fist through side by side ...so now i have a patch to put in before i bondo it ....just got to make it last 3 more years then another 5 after the 3 ...you know how it goes
Old 08-06-2005, 08:23 PM
Dallas B's Avatar
Dallas B Dallas B is offline
Duke of Rock
Send a message via Yahoo to Dallas B
Try Grainger. http://www.grainger.com/Grainger/wwg/start.shtml
http://www.grainger.com/Grainger/sea...h_type=keyword
http://www.grainger.com/Grainger/pro...1768118&ccitem=
The time and money you spend on trying to build one it would be cheeper to go this way.
Dogs are nicer than people. Not only that, but dogs are smarter than horses. *Winner SFT Best Sig Line 2005* ( http://www.indierevoltmg.com/ )
Old 08-07-2005, 01:13 PM
pknoeber pknoeber is offline
Dallas, aren't you building the oil cooler using (or at least it would take me this long) about a gillion man-hours
Old 08-07-2005, 01:42 PM
Dallas B's Avatar
Duke of Rock
I knew If I posted this someone would bit me on the azz...But remember I am Retired...so all I I have to do Is Play with rocks and projects....But some times it is cheeper just to buy....lol.OUCH
Old 08-08-2005, 01:05 AM
caseydawg
Guest
Posts: n/a
I have one like the Northern , $89.00 at the travelin tool sale. I'm on my second one , plum wore out the first (5yrs) and when you look at the price of replacement sand hose , it's just cheaper to pick up another one and strip the old one for spare parts.
Ray
Old 08-08-2005, 05:15 AM
Sberry's Avatar
Sberry Sberry is offline
GOD of Strawberries!!!
I agree, a small one I would buy. I did make mie but one like it cost a lot more and it made sense, I made shop rates building it. I buy 1/8 XH pipe nipples 6 inches long and cut in half for nozzels.
Old 08-08-2005, 01:16 PM
Sberry's Avatar
Here is a pic,,, my guy put some software on blocking the attatchment window, I need to fix it but this one is on my site. http://www.urkafarms.com/Welder_Pict...nd_blaster.JPG
