Old 07-18-2013, 10:56 PM
Camaro Zach's Avatar
Default Small press brake
I finally got the urge to build a press brake for my 20T Harbor Freight press after all the years of seeing them here.
The upper die is ~5/8" scrap plate hand ground to around 30* angle
Base is two pieces of 3/8"x6" flat bar
Lower die is two pieces of 1 1/4"x1/4" angle iron turned up 3/32" on each side (to bend past 90*)
Dual row valve springs for a return
And 5/8" bolts drilled/tapped into the base allow the upper die to slide up/down freely
When drilling/tapping the base I used 1-2-3 blocks to space it off the table. Is this pepper procedure? I am learning slowly how to use these tools properly.
Sent from my iPhone using SFT
ID:	107732   Click image for larger version
ID:	107733   Click image for larger version
ID:	107734   Click image for larger version
ID:	107735   Click image for larger version
Buggy
Old 07-19-2013, 08:29 AM
Nice job that's gonna be handy for you, you will use it more and more all the time.
Old 07-19-2013, 08:33 AM
Lu47Dan's Avatar
Lu47Dan Lu47Dan is offline
Connoisseur of Old Iron
Cam, parallels, 1-2-3 blocks or even a pieces of seek the same thickness will do the job. Depends on the amount of accuracy needed.
One thing you might want to add to the upper die is a ring to keep the ram from slipping off of it.
Dan.
Miller XMT-304 Multiprocess
Miller 10-E Wire Feeder
Hobart AC/DC stick welder
Hobart 175 Mig
Craftsman O/A set
Turbo torch and B-tank
Old 07-19-2013, 01:33 PM
Dan.
That is in the plans, I just couldn't wait to test it out last night.
Buggy
Old 07-19-2013, 07:15 PM
weldor2005's Avatar
Perpetuus Discipulus de Vita
Did you put a space in between the to legs of the angle on the bottom die? I am going to make one of these myself soon as well, and would be apt for getting ideas.
David
My YouTube Channel
Old 07-20-2013, 11:53 AM
Ended up with about 1/8" of space on accident. Not sure if less or more would help any.
I bent a small piece of 1/4" plate just past 90* and it cracked. So maybe more gap on lower dies and a larger radius on the upper die to achieve a larger bend radius for thicker material.
Buggy
Old 07-20-2013, 12:15 PM
Steve60 Steve60 is offline
nice! so you could easily make an extra die to hold fingers and have a box and pan brake too?
Old 07-20-2013, 01:21 PM
aametalmaster aametalmaster is offline
Cool
Nice job...Bob
Bob Wright
Metal Master Fab
Salem, Ohio Birthplace of the Silver and Deming Drill.
http://www.ceilingtrains.com
Miller MM185 with 185 SpoolMate
Old 07-20-2013, 02:25 PM
Shawn C Shawn C is offline
around here so.ewhere i have a chart that tells you the required size for the bottom die as well as the force it will take to bend. if i can find it i will try to upload it for you
Old 07-20-2013, 03:11 PM
Cool
The biggest thing is the thicker the metal the wider the bottom die opening needs to be.
http://www.accurpress.com/toolingref_tonchart.html ...Bob
Bob Wright
Metal Master Fab
