Old 02-09-2013, 03:28 AM
clive's Avatar
clive clive is offline
Default hope this is of use to someone
I am in the process of making a shop press and have poached ideas and blatantly copied presses that others have made. In looking at them a couple of questions were asked about pins and welds so this may help.
To calculate the shear strength of a pin take cross sectional area x3.142(pi) x shear strength of material = shear strength of pin.
eg. my pins are 19.5 mm dia. I always calculate in inches so 19.5 /25.4 = 0.767" dia
so rad is 0.3835
0.3835 x 0.3835 x 3.142 x 35 ( I used 35 ton steel) = 16.17 tons.
my pins are in double shear so to shear each side takes 32.34 tons and both sides together 64 tons.
As I'm using a 20 ton jack the pins are well able to handle the tonnage.
Now on to weld strength. If you use a 60XX rod the 60 denotes 60,000 lbs tensile, a 70XX rod or wire 70,000lbs and so on.
If you have done a fillet weld and want to know the strength it is leg lengthx0.707(sin45) x weld length inches x tensile strength weldment.
Using a 1/4 inch fillet as an example and 5 inches long using 60XX rods =
0.250 x 0.707 x 5 x 60,000 = 53,025 lbs shear strength thru the length. divide this by 2240 (pounds per English ton) and you get 23 tons shear.
Welds are deceptively strong.
If anyone wants to rewrite this to make it clearer please do.
Clive
It's So Easy
Old 02-09-2013, 07:49 AM
Wolfram's Avatar
Wolfram Wolfram is offline
I think you might need to throw in a factor of .75 there since the shear strength is about 75% of the tensile strength.
(So shear strength of your pins is probably about 12 tons.)
See table at:
http://www.engineersedge.com/manufac...s_strength.htm
Old 02-09-2013, 07:55 AM
clive's Avatar
Yep, but still a good degree of safety at 12 tons. Thanks for pointing that out.
It's So Easy
Old 02-09-2013, 08:30 AM
cramd's Avatar
cramd cramd is offline
Drivin' Fool
so rad is 0.3835
Clive
That may be a bit confusing, as North America generally used 2000 pounds as a ton (short ton), versus the long ton of 2240 pounds you are referring to. See reference here: http://en.wikipedia.org/wiki/Long_ton
Miller Thunderbolt XL AC/DC
Hobart Handler 190
Old 02-09-2013, 10:30 AM
Thank you for posting. That info helped clear some things up in my mind. It is always nice to learn something everytime I come to this forum from the great people posting. This is what makes this the best forum!
Old 02-09-2013, 01:01 PM
DrBob's Avatar
DrBob DrBob is offline
Default Kudos
Well, we like to think so!
DrBob
So THAT'S what a "long ton" is!
Old 02-09-2013, 04:00 PM
willy willy is offline
Cool - thanks for posting that! Learn something new every day! Long Ton, Short Ton, now I just need to figure out what a $h!t Ton is...
Old 02-09-2013, 06:00 PM
clive's Avatar
Lets add to that - the metric ton is 2200lbs. But metric, long or short they are all in a ballpark figure.
It's So Easy
Old 02-09-2013, 06:05 PM
jb-mck's Avatar
jb-mck jb-mck is offline
Anyone looking for a good units converter, try this one. http://joshmadison.com/convert-for-windows/
Sent from my iPad using SFT
Old 02-09-2013, 06:21 PM
GAS's Avatar
GAS GAS is offline
That would be a crap load more than either the long, short or metric tons
Jack A** of many trades
