Old 12-01-2012, 08:48 PM
NOBLNG NOBLNG is offline
Default Last caulking gun I'll own.
I was attempting to install a windsheild in my Jeepster, and my POS caulking gun could not push the adhesive through the nozzle. I had the nozzle cut to deliver about a 1/4" diam. bead. I built this one using a 1/2" coupling nut and redi-rod. It easily pushes the same stuff out of a 1/8" uncut nozzle, and stop immediately when backed off.
Name:	caulking gun 001.jpg
ID:	98497   Click image for larger version
Name:	caulking gun 002.jpg
ID:	98498   Click image for larger version
Name:	caulking gun 003.jpg
ID:	98499   Click image for larger version
Name:	caulking gun 005.jpg
Last edited by NOBLNG; 12-01-2012 at 10:41 PM. Reason: remove embedded images; upload attachments
Old 12-01-2012, 08:51 PM
You're living up to your Handle. No Bling, just rock solid simple.
Aaron Neville
Old 12-01-2012, 09:16 PM
akabull's Avatar
akabull akabull is offline
Maine-iac
I can't see the pics. But maybe it is the server here at work blocking them?
Chris in Maine
Old 12-01-2012, 09:33 PM
Charlie C's Avatar
More STEAM!!
That looks interesting. I would like to see how you built the nozzle.
Old 12-01-2012, 09:56 PM
Boogity's Avatar
Boogity Boogity is offline
Charlie - I'm pretty sure the nozzle comes on the tube. Nice job NOBLING.
Boogity
Our Republic can survive a Barack Obama, who is merely a fool. It is less likely to survive a multitude of fools such as those who made him our president.
Old 12-01-2012, 09:59 PM
Scrapper Greg's Avatar
NOBLNG Excellent idea. Consider it stolen!! Gotta build me one. Charlie, I think the front is a washer. Allows the factory nozzle out just like a regular caulking gun does.
MAGA
Old 12-01-2012, 10:09 PM
The front and rear are 3/16" thick washers that I cut with my plasma. Sides are 1/8"x3/4" flat bar. There is a 3/16" thick slug that gets dropped into the tube before loading it. It has another washer tacked to it to keep the redi rod centered. Put a little anti-seize in the coupling nut for smooth operation.
Old 12-01-2012, 10:13 PM
I sincerely hope it's also the last time you embed pictures here.
Please read the first item in our FAQ.
I wrote it especially for you.
Old 12-01-2012, 10:24 PM
I will remember that. Thanks for fixing it.
Old 12-01-2012, 10:31 PM
Actually, I think I probably screwed up & attached only the thumbs of the numbers 2-4.
You might want to replace them via edit/go advanced/manage attachments.
