Can I hold an electrode while welding?
Hi grumpy, I hold the welding rod with my off hand all the time. Sometimes it does get exciting if my glove it wet tho
hi grumpy this may help you
use your side cutters cut full weld rods in 1/2. these shorter rods will give you much more control. i do this in tight quarters sometimes, like reaching
up under an auto. i also normally guide rod with 2nd hand also. |
Director of Purchasing Tact is for people who aren’t witty enough to use sarcasm. |
It is done all the time just be sure to use a good thick glove with no damage on the hand holding the stick for longer burn protection. I have a big box of right hand gloves and no lefts from this practice. Terry
edit sp and clairity Terry |
I almost always use two hands. I like to guide the electrode with my index finger
Jeff
Thanks for all the responses. Now I feel more confident about touching (holding) the rod when welding. Also thanks for the tip about cutting the rod in half--never though about that.
if your in a tight spot and starting a new rod and don't have room....clamp the holder at the half spot on the rod ....give rod couple of bends to break the flux off and make contact with the holder ....then bend the part you ain't going to use down along the handle...hold rod and handle at same time...cutting them can be a pain and that is just another tool you have to look for
Director of Recruitment, Overseas (by appointment) I don't suffer from insanity...I enjoy every minute of it --------------------------------------------------- |
