Old 11-02-2012, 10:32 PM
Default Mag Drill = Portable Milling Machine
I had to enlarge some holes in a excavator bucket, and came up with a solution of making an boring bar for the mag drill. (Actually, I modified a boring bar I made for a previous job for the mill) The existing holes were 1 5/8" and I needed to make them 1.765 or 45mm.
First I had to clamp a 3/4" piece of plate to the bucket to hold the mag drill. Then I used a 1 5/8" rotobroach bit to center up on the hole, put the boring bar in and started boring. I had the cutter pretty well set for the cut, but did adjust a little after the first cut. The setup wasn't perfect and the holes were slightly mis-aligned with each other , but with a little air file work, I got the pins to slide in! The dirt will never know!
ID:	97338   Click image for larger version
ID:	97339   Click image for larger version
ID:	97340   Click image for larger version
ID:	97341   Click image for larger version
Old 11-02-2012, 10:40 PM
Neat idea. Always interesting to see the creative solutions that others come up with. That's a brute of a mag drill, too...
Old 11-02-2012, 11:30 PM
AdreamSoReal AdreamSoReal is offline
That is a great idea! Nice thinking.
Old 11-02-2012, 11:52 PM
The cut looks nice & shiny.
Old 11-03-2012, 02:27 AM
camdigger's Avatar
Roving Reporter
Glad it all worked out for you.
You do realize that your rig up is just a few doodads short of a "lineboring" setup, right? A couple pillow block bearings and a U joint drive shaft, and presto, a line boring rig....
Old 11-03-2012, 05:17 AM
J bar J's Avatar
J bar J J bar J is offline
I love you footless clamp. Great Idea!
Most people are about as happy as they make up their minds to be!
Abraham Lincoln
If your scared say your scared!!! :eek
That's Harder Than Chinese Arithmetic!!
Old 11-03-2012, 07:12 AM
Jeff in PA's Avatar
Jeff in PA Jeff in PA is offline
Nice job.
McMaster Carr has replacement feet for C clamps.
http://www.mcmaster.com/#standard-c-clamps/=k02mma
Old 11-03-2012, 07:24 AM
endmill endmill is offline
Default noddle
Thats using you noddle
Old 11-03-2012, 08:39 AM
digr digr is online now
Great setup
Old 11-03-2012, 08:55 AM
Bit more work and you would be set up for lineboring, as was mentioned.
Bucket looks like a backhoe bucket, but maybe a smaller excavator bucket. I see it has the second set of holes for loading trucks and the like to get a little more 'curl'.
