![]() I'm curious, how prevalent is this type of business? As far as I know there is no such service around here. It looks like a good business opportunity for someone. It should transfer over to farm equipment as well.
Buy it cheap and stack it deep Klaatu barada nikto |
To the best of my knowledge, every Cat dealer and every heavy equipment dealer has that type of service. And they do have a lot of heavy duty tools on on the truck as well as a mounted mobile crane, welder, air compressor and etc.
And the service trucks are generally large heavy duty units also. As for farm equipment dealer's mobile mechanics, not as well equipped as the Cat mobile mechanics nor as common either at least not in this area. They generally seem to use heavy 1/2 ton to maybe 3/4 ton pickups at the most.
Running away is the coward's way out of war. Appeasement is the coward's way into one. Biden & Harris is our enemies favorite candidates In time the right project will find the scrap pile, no need for the scrap pile to go out looking for a project. http://www.swiftvets.com/phpBB2/viewtopic.php?t=24981 http://tosettherecordstraight.com/index.php |
I used to work for a construction equipment dealership. We had 3 men in the service dept. All had trucks, 3/4 and 1 tons. Worked on everything from Target saws to Barber Greene pavers and everything in between, in the shop and in the field.
MAGA ![]() |
I question the pay rate, they said $250 an hour. 8 hours = $2000, There was 2 mechanics doing the job. Our shop gets $100 an hour plus mileage for Mobile maintenance, that is for 1 tech. The $250 a hour was actually $125 per mechanic.
It leads me to believe that Todd asked for it to be done ASAP, and agreed for 2 mechanics. Even at those numbers $2000 ^ 8 hours= $250, doesn't show any mileage fees, I don't think those mechanics would have drove out there for free. Out in the woods, you could drive only 50 miles and it can take you a couple of hours to do it. I believe the bill statement was more like 2 mechanics @ $100 per hour each = $1600, than a mileage charge of $200 per mechanic / service truck = $400 $1600 + $400= $2000
"Government is not the solution, it is the problem!" RIP Ronnie,,, |
If it was anything like the rest of TV, it could have been 1500 and the rouned up to 2000 to make it sound better. The land of TV and the real world truth don't always equal.
Dt
Sero Sed Serio Acta non verba |
Sometimes it doesn't matter what the bill is because the down time is far more costly. Customers sometimes ask what parts cost, in my mind I ask does it matter damn thing won't run with out it.
I had a tractor in the shop before fall work with a hydraulic leak. Blown $0.72 oring. It took 3 days to replace that damn o ring because we had to remove the cab to get at it. $200,000 machine down because of a freaking o ring that the factory missed tightining the damn jam nut on the fitting! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
The person who said "no guts no glory" is probably dead. There is no such thing as too much ammo.....the real problem is a target deficency. |
The big name equipment wrenches AKA dealerships Are about $135 /hr for the truck and one man. figure 4 hrs travel ( 2 each way) with mileage and a fuel surcharge gets you up there.
The travel alone will be about $1000 when taxes get figured in. The theory is that down time costs more. Most owner /operators are pretty handy wrenches and often do a lot of the grunt work before the big buck guys get there. I quite often get called to work on machines mostly on planned repairs and service. Pick up at my door and delivered back $ 100 /hr door to door because that adds up to about mileage charge from the dealership trucks. Lots of bull work but I am the knowledge guy and there are usually enough grunts that I do not get overworked. ![]()
Life beats the alternative hands down. |
I do mostly agricultural repair but also see some industrial equipment from a couple of customers.
My old one ton is pretty basic compared to some others around here, but it as a crane, welder, air compressor and all the basic tools. I charge $70.00/hr from the time I leave home till I get back, plus $1.25/mile and $2.00/hr for supplies, more if I'm welding. I'm raising the rate in the new year but all my customers are alright with it. Many of the more fancy units go out for $100.00/hr or more, but I seem to be making a decent living. Some of the rookies the dealerships send out on $125/hr units are a crying shame, no experience and no work ethic, they're not all like that but there seem to be more and more.
why do all my favorite pastimes, except one ![]() |
Just my thought on the subject.
RIP Cutter |
