![]() ![]() Monday it rained again but I started getting the tools gathered up to do the job while I waited for the rain to quit. While waiting for the rain to quit after finding all the tools and tooling I decided to straighten out some of the shop, that started out as the "Hunt for My Setscrew Assortment.". ![]() ![]() So the rain had quit by that time and I was back to the original job of taking the bucket and cams off the backhoe. It was a fight to get the bucket and cams off the hoe. I got the bucket off and the cams came off just before supper. After supper I went and bought another 50' of 3/8" poly rope, and started to finish taking the pins out of the last cam. I got the one pin off and the other one (main bucket pivot pin) needs the back of the nut ground before the I can remove it. That operation requires a bit of finesse, so I punted for the night as the light was not good outside the shop. Today I am planning on welding the pin holes up in the cams and either building up the pins or make a temporary pin until I can get the right stock to make a new one. While I am waiting for the parts to cool I am going to splice the last 50' section of rope to the one spliced yesterday. Dan.
Tools to Men are like Shoes to Women , you can never have too many !! ![]() Used diesel engines are an adventure anyway you look at them !! ![]() Miller XMT-304 Multiprocess Miller 10-E Wire Feeder Miller Spectrum 2050 Plasma Cutter Hobart AC/DC stick welder Hobart 175 Mig Craftsman O/A set Turbo torch and B-tank |
The cams were worse than I thought and the pins not worth rebuilding, I am off to my favorite scrap yard to see if I can locate enough RS to make new pins. All three pin bores need welded up and bored out to a press fit, lots of welding, drilling and boring out need to be done.
Dan.
Dan,
I've got some 3" dia. solid bar iff'n you'd like me to carve up some bushing's. P.M. me with some dimensions. What exactly is the "cam" on a backhoe bucket ? |
Doug, this old backhoe has two levers that mount to the bucket end of the dipper stick. These two levers connect the bucket cylinder to the bucket and the bucket to the dipper stick. When the cylinder is actuated these levers move the bucket. I will post some pictures later today as I got side tracked again on OPP after getting home from the scrapyard.
I will get some measurement today after I get the pin made. Dan.
I finished building up the worn out holes yesterday and have the one cam set up in Emma.
I took a lot of time and 7018 rod to build up the damaged areas. The first thing I need to do today is mill the outside surfaces of the cams flat. I built up the worn areas that the old castle nuts tightened against. Once the welds on that side are machined, then I can weld up the inside surface and machine it.
Dan.
More photo's.
Doug, I did not get a bushing out yesterday Will try to get that done today. Dan.
a press ? or do you mean to machine a new one ? Either way, the shop (and materials) is at your disposal. |
Doug, the bushings are still in the dipper. I ran out of daylight before I could get to them. I am going to try to drive them out today.
Dan.
The base metal build up is done on both cams, one cam is milled back to the original thickness, all that is left to do on that one is spot and drill the holes.
The bushings are out of the bore and a friend thinks he might have a set of bushings that will work. I had to split one of the bushing to get it out of the bore. There was a spacer in between the bushings that I have to clean up and re-use. Once the machine work is done on the cams I can start on the pin. I have a pretty good idea of how the pin should be made. Dan.
I did not get to the shop yesterday as I was coming down with a cold, I am going to try today but I am still feeling lousy.
Dan.
