Old 07-07-2011, 12:51 PM
H80N's Avatar
H80N H80N is offline
That Man Behind The Curtain
Default Warning GE Silicone II Caulk not curing!!!!!
Insulated and sealed a cable a few days ago (or at least I thought that I did)
I had opened a brand new tube of clear GE Silicone II... this stuff is not curing.... not even tacky... found out after the fact that the new "Environmentally friendly" formulation is not likely to cure if it is past its use by date.. now I have a huge mess to clean up and then need to repot the cable junction...
"THANK YOU GE!!!!!!"
here are some links
http://fixithouse.blogspot.com/2009/...k-warning.html
http://answers.yahoo.com/question/in...4065351AAsX1VW
http://forums.jlconline.com/forums/s...ad.php?t=41675
hope this saves anybody else a mess... yet another reason for me to avoid GE
Old 07-07-2011, 12:57 PM
Jim-TX's Avatar
Jim-TX Jim-TX is offline
Chairman of the Headboard
Aren't we glad that it's environmentally safe though. The fact that it doesn't work is secondary.
Jim
Old 07-07-2011, 01:03 PM
monckywrench's Avatar
trust but verify
Thanks for the warning!
Once I discovered 3M 5200 Sealant Adhesive I'm only going to use sillycone "caulk" on items where the need to disassemble is more important than sealing.
Got a couple tubes at a flea market a while back and I'm in love. It's almost as wonderful as aircraft fuel tank sealant (Aircraft Spruce has that) which tops my fave goo list but is more expensive.
It's rated for thru-hull fittings on boats. It also sticks leather flaps to welding helmets, which many adhesives won't do well.
Old 07-07-2011, 01:09 PM
H80N's Avatar
This is a non acetic acid formula with "BioSeal"
here is the tube........ the expiration date is embossed on the tube end seal where the hanger is... and very difficult to see...
Keep in mind that this was a brand new tube bought and opened just for this job....
Old 07-07-2011, 01:46 PM
Turdle Turdle is offline
so excess tubes in the landfill, because everyone is throwing it away is environmentally friendly? All of the sudden I am hit by Ironic confusion-
Old 07-07-2011, 03:58 PM
getatorch's Avatar
Tuned-Up Big Builder
I buy lots of clear GE silicone for work and I had that happen one time but, it was the blue and white tube. Never cured out over a week. Sticky pain in the ass it caused.
"Freaking" is what you feel when things go wrong. The other word really refers to what happens when things go right... That one is only bad if it's against our will".
Old 07-07-2011, 04:02 PM
Says lifetime warranty. Email your problem. Bet they will handle it for you.
Woodrow Wilson
Old 07-07-2011, 04:20 PM
H80N's Avatar
Emailed GE..... will keep you posted... BUT.....will not be holding my breath awaiting reply
Old 07-08-2011, 01:44 AM
Dave Lee's Avatar
Dave Lee Dave Lee is offline
Armchair Webbie
Yeah, they're not kiddin' about that expiration date. I used some that was just a little out of date on my cellar doors. it was still gooey after a week. Had to unscrew the mounting flanges, wipe it all off and re-apply new stuff. Grrrrr.
Wouldn't have been so bad but, this was the final step, after a very lengthy rework of a set of brand new doors, to fit my oddball cellar entrance.
Dave
Old 07-08-2011, 11:19 AM
H80N's Avatar
Default So Much for GE customer service...
"wish in one hand and sh*t in the other and see which one fills first"
got response from GE... basicly "Tough Sh*t"
I know I will spend my money elswhere in the future!!!!!!
Hello,
I am very sorry to hear what happened. When Silicone II expires (the same way it has been forever) the silicone will not cure. It is the stores job to rotate their stock and get expired material of any product off the shelves. I am not sure what you mean by "new environmentally friendly formulation" because as long as the silicone II has been out it has been the same.
Matthew Brown
Consumer Specialist
Momentive Performance Materials
866-ASK-GESA (866-275-4372)
fax: 304-746-1654
-----Original Message-----
From: siliconeorders@momentive.com [mailto:siliconeorders@momentive.com]
Sent: Thursday, July 07, 2011 5:16 PM
To: ASK GESA
Subject: From construction sealants website
Insulated and sealed a cable a few days ago (or at least I thought that I did) I had opened a brand new tube of clear GE Silicone II... this stuff is not curing.... not even tacky... found out after the fact that the new \"Environmentally friendly\" formulation is not likely to cure if it is past its use by date.. now I have a huge mess to clean up and then need to repot the cable junction...
This is a non acetic acid formula with \"BioSeal\" GE280.... the expiration date is embossed on the tube end seal where the hanger is... and very difficult to see...
\"THANK YOU GE!!!!!!\"
