Old 04-12-2011, 01:46 PM
aametalmaster aametalmaster is offline
Cool Pump shotgun barrels to a semi auto.
I posted this in the firearms section too but those needing a cross slide hole driller might be interested.
I do a lot of these shotgun barrels for my dad. The semi auto's need a hole or two drilled inside the barrel ring and of course its on an angle. The pump shotgun barrels will work with the hole(s) added. He was using a guy in Akron but he quit doing them on his mill because the setup was to hard or he broke too many drill bits. Well i set them up on my lathe with my cross slide hole driller and a cheap pawn shop drill and i haven't broke a bit yet. Its prob 10 minutes from start to finish. I use a center drill to spot where the hole goes then switch to a regular drill bit. I have some pics of a barrel with 2 holes but i don't have it on my computer....Bob
ID:	74547   Click image for larger version
ID:	74548   Click image for larger version
ID:	74549   Click image for larger version
Bob Wright
Metal Master Fab
Salem, Ohio Birthplace of the Silver and Deming Drill.
http://www.ceilingtrains.com
Miller MM185 with 185 SpoolMate
Old 04-12-2011, 01:57 PM
MAC702's Avatar
MAC702 MAC702 is offline
set phasers to .50 caliber
For what brand of shotguns does this work? I can't picture this working on Remingtons.
Old 04-12-2011, 02:03 PM
Cool
I know this barrel was for a Remington because i shot the gun, i am thinking old model 878. The barrel was for an 870. I also did a few for Winchesters...Bob
Bob Wright
Metal Master Fab
Old 04-13-2011, 08:43 AM
Floptop's Avatar
Floptop Floptop is offline
Thanks for showing, many times I get more out of seeing how the setup is done than the actual piece being made.
Old 04-13-2011, 02:04 PM
MAC702's Avatar
Ah, I've never seen a Model 878. My 1100 sure has a wider collar than the 870-series, though. Interesting!
Old 04-13-2011, 05:34 PM
ken98k's Avatar
ken98k ken98k is offline
I think the hole driller is a kool attachment but, I'm curious about why so many semi-auto shotguns are missing their barrels in your area??
Old 04-14-2011, 01:26 AM
Amigo Amigo is offline
Yup, I'm convinced. I need to make a cross-slide drill fixture for my lathe. Yup, no two ways about it.
Thanks fer the convincin
Old 04-14-2011, 07:45 PM
Cool
Lots more how to make it pics here http://groups.yahoo.com/groups/southbend10k/ ...Bob
Bob Wright
Metal Master Fab
Old 04-14-2011, 07:46 PM
Cool
The 878 is like a 1959 era gun...Bob
Bob Wright
Metal Master Fab
Old 04-15-2011, 12:05 AM
Bob, thanks for the link!
