Old 03-29-2011, 10:00 PM
pugsly's Avatar
pugsly pugsly is offline
Default Power Pusher
I am building a power pusher to move cars and trucks around the lot at my shop. Since the manufactured ones are so expensive, I have been gathering parts and supplies to accomplish this.
I am using a 12 volt dc winch motor that a customer put a deposit on and then never picked up.
Kevin (engineman56) offered me a transaxle from a lawn tractor, so that will cure the problem of axle, wheels and gear reduction.
For power I am using two 6 volt golf cart batteries (also will serve as weight for the body of the pusher.
As I build, I will take high resolution pics (learning from past posts)
I am going to start on Saturday.
Old 03-29-2011, 10:03 PM
Tom Zachman's Avatar
Dodge City Marshal
God Speed pugsly.
New sig line:
Old 03-29-2011, 10:38 PM
pugsly's Avatar
here are some examples of what I am building.
ID:	73857   Click image for larger version
ID:	73858   Click image for larger version
Old 03-29-2011, 11:10 PM
That's what I'd call a mule, pugsly.
Old 04-02-2011, 09:30 PM
pugsly's Avatar
I have to say 'sorry'. I got carried away and forgot to take pictures of the build of the frame, and before I knew it.... well this is how far I got today. Kevin was over to help set up my bandsaw and give me some pointers. Pardon my (as Kevin calls it) 'Silverback' Welds, Thank God for grinders!
1. The winch motor installed on top of the transaxle.
2. belt drive (only the lower motor mount is installed)
3. The frame with the transaxle, motor and batteries installed.
Cutter, (laughing) that is my actual Mule in the background of the 3rd picture.
ID:	74068   Click image for larger version
ID:	74069   Click image for larger version
Old 04-02-2011, 09:46 PM
pugsly's Avatar
Tomorrow I plan on installing the upper motor mount, the handle and finishing the wiring. From there I plan to cut the sheet metal for the body, paint it and have the mount for the rubber pad rolled.
I will try to be more attentive to pictures during the rest of the build.
Old 04-02-2011, 10:32 PM
partsgurut's Avatar
partsgurut partsgurut is offline
looks good pugsly, we have one at work and it gets used a lot. I had to take the motor down to have it rebuilt last year, it is just a ford starter motor. That was after about ten years use. I think you will be happy with how yours comes out.
Tony
“Use it up, wear it out, make it do, or do without”
Old 04-03-2011, 12:31 AM
akabull's Avatar
akabull akabull is offline
Maine-iac
very nice so far, looking forward to seeing the rest.
Chris in Maine
Old 04-03-2011, 06:08 AM
Looks good, I have never saw such a animal
Old 04-03-2011, 12:57 PM
kbs2244 kbs2244 is offline
Others might want to check these out.
I am sure they are well used.
But you are getting 2 and all the design work has been done.
http://ibid.illinois.gov/detail.asp?id=5296
Downers Grove, IL is a western suburb of Chicago.
This site is about 30 miles from the city center.
