Old 09-14-2010, 05:19 PM
panhandle_redneck's Avatar
panhandle_redneck panhandle_redneck is offline
Default How to cut a hole in glass?
How would you cut a 3 inch hole in glass? Square or roundmakes no difference.
More specifically in the bottom of wine bottles.
I need the bottoms open or completely off.
What would be the easiest way? What would be the cheapest way?
I have most tools available that yall have but I will probably have to buy something bit or cutter wise.
So how would you do it?
I hear and I forget.
I see and I remember.
I do and I understand. --Confucius
Old 09-14-2010, 05:28 PM
flametamer's Avatar
The easiest way would be to cut the bottom off instead of putting a hole in the bottom. Would that work? I get nervous thinking about drilling through glass.
Dt
Sero Sed Serio
Old 09-14-2010, 05:32 PM
Ok. How?
Scratch and pop (??) it off?
Bandsaw?
Grinder?
Old 09-14-2010, 05:40 PM
OleDog's Avatar
OleDog OleDog is offline
I have used my bead blasting cabinet to put holes in plate glass. I just took a rubber washer and held it over the glass and blasted away until the beads wore their way thru the plate. It worked, but wasnt particularly precise. I only was trying to see if I could do it, so a 1/2 in hole is as big as I've ever cut. You might be able to adapt it to your project.
OleDog
Old 09-14-2010, 05:55 PM
brucew's Avatar
brucew brucew is offline
Sorcerer's Apprentice
Back during the 70's there was a bottle cutting craze. I bought a "kit" and made steins, vases and a bunch of other items. I thought I was cool.
The kit consisted only of a glass cutter and a "rapper". You would cut a line on the outside of the bottle all the way around. The Rapper was then inserted into the bottle and tapped slowly and lightly around the scored line. You could see the line breaking as you tapped if you watched closely enough.
Usually after it was tapped all the way around the bottom would just fall off, but it seems like I remember sometimes having to place the tapped bottle in hot water, then quickly quenched in cold water. That would usually finish the cut.
Old 09-14-2010, 06:02 PM
This was thought about.
Score the outside and insert a dowl pin and stand itup on the dowl. Apply down pressure on the bottle onthe pin and rap and tap the outside of the bottle.
Sound like it would work?
Old 09-14-2010, 06:04 PM
Andyman Andyman is offline
happen to have watch this done on a TV show a few months back and found it for you to watch. you'll either have to watch it all or skip through till you find the part where they cut the glasses.
but if I remember right, the guy scribes a line in the bottle
then heats up with a torch
then dunks it in water
then the bottom breaks off with a nice clean cut.
here is a link of the episode of garage mahal:
http://www.hulu.com/watch/161246/gar...al-wine-garage
Andy
Old 09-14-2010, 06:20 PM
Thanks for the link Andy. I will watch it tomorrow where I have high speed.
Old 09-14-2010, 06:33 PM
Those videos from EMAS that were posted awhile back show how to do it in the solar panel build.
It shows the process starting at 1:20 into the video
Old 09-14-2010, 06:39 PM
downtime downtime is offline
Rotozip has a bit for glass blocks.
"An honest man can feel no pleasure in the exercise of power over his fellow citizens." Thomas Jefferson
