Old 07-05-2010, 05:27 PM
Vernon's Avatar
Vernon Vernon is offline
Default Homemade Heavy built 12" Bucket
Built a heavy bucket for a small track hoe the bucket is mostly 1/4" Plate 3/8" sides at the open and 1/2" at the bottom for the first 4"
ID:	62982   Click image for larger version
ID:	62983   Click image for larger version
ID:	62984   Click image for larger version
ID:	62985   Click image for larger version
Old 07-05-2010, 06:04 PM
OLD MAN's Avatar
OLD MAN OLD MAN is offline
2-3-1940 to 3-8-2011
Nobody was faster
very nice work.
Old 07-05-2010, 06:18 PM
RogueWelder's Avatar
RogueWelder RogueWelder is offline
I've build a lot of buckets in my day. And I think that one looks great. If you could find an old grader cutting edge to put on the lip it would be perfect. Give you that hard steel for wear.
I said to just Tac it!!
Old 07-05-2010, 06:19 PM
Scotts Scotts is offline
Vernon,
Do you have a list of the equipment you used to make this? Do you use a plasma cutter, torch, what type of welding equipment? No need to be too specific. Stick for welder, hand operated torch or plasma will be fine for my information.
Thanks for posting this. Dad has a small Kobelco he wants a small bucket for and a thumb to go with.
Old 07-05-2010, 06:32 PM
Vernon's Avatar
Default Tools need
Vernon,
Miller 251 with .045 Dual Sheild Wire for welding
O/A Torch for cutting
Hougan Mag drill for large holes
Drill press for small holes
Small Grinder for grinding
Little Hard work for the rest Hope thats what you wanted Scott If you need anything else just ask Vernon
Old 07-05-2010, 06:48 PM
Vernon's Avatar
Default Bucket
Thank You I made some bolt in teeth for this bucket
ID:	62987   Click image for larger version
ID:	62988   Click image for larger version
Old 07-05-2010, 06:50 PM
Vernon,
Yes that is it.
Thanks
Old 07-05-2010, 07:11 PM
Vernon's Avatar
Default Templates
Vernon,
Yes that is it.
Thanks
I made some patterns for the top side edges and hook up brackets if I could help in any way let me know.
ID:	62989   Click image for larger version
Old 07-05-2010, 09:39 PM
Thumbs up
Very clean and effective build Vernon.
Tidy. I like tidy fabrications. (as in simplistic)
Old 07-05-2010, 10:05 PM
RandomDave RandomDave is offline
Nice job indeed. How did you make the teeth? Are they from a solid chunk of regular steel, or a special harder alloy?
