Old 05-28-2010, 03:59 PM
nctox's Avatar
nctox nctox is offline
SFT Navigator
Default Brush Fork
I thought I would post a couple of pics of a brush fork I just finished. I saw this on line and in a NT catalog, and thought it would be a good learning project for me. I made the tines and back from 2"x3"x3/16" tubing, and the clamps from 1/4"x4" plate. I'm sure I could have used smaller tubing, but this was a better price in stock vs. ordering from my supplier.
I will paint it later, but I used it this afternoon moving brush and rotten logs and it seems to be plenty strong for my purposes. It is quite heavy and much stronger than my bucket, so I had to weld a 2"x1/4" strip to the bottom of the bucket to stiffen it.
You can see from the pics, my welds aren't great, but I'm learnin'!!
ID:	61436   Click image for larger version
ID:	61437   Click image for larger version
ID:	61438   Click image for larger version
ID:	61439   Click image for larger version
Trying to make retirement as much fun as 40 years of working
So far,,,I'm succeeding.
"I don't care if you like me or not. I'm not even on Facebook."
Old 05-28-2010, 04:11 PM
Bender's Avatar
Bender Bender is offline
One Lone Sub
Looks good nctox!
Boise Paint Contractor
Facebook
How fortunate we are!
Old 05-28-2010, 04:56 PM
brucew's Avatar
brucew brucew is offline
Sorcerer's Apprentice
Looks really good!
Old 05-28-2010, 06:37 PM
akabull's Avatar
akabull akabull is offline
Maine-iac
next thing you know, you are going to be adding a grapple! Looks great. Good job!
Chris in Maine
Old 05-29-2010, 09:48 AM
DrBob's Avatar
DrBob DrBob is offline
Default Nice!
Nice work, Nctox! I was wondering how you made the points on the front ends of the tines? Did you bend one wall of the tubing down or did you just cut the tubing on a 45 and weld a piece of plate over it?
How much weight do you think the fork will hold?
DrBob
Old 05-29-2010, 05:33 PM
nctox's Avatar
SFT Navigator
DrBob
Thanks. If I were more computer savvy I could draw a diagram, but I'm not. Anyway, I initially tried to cut out two triangular pieces from each 2" side of the tine, to bend the 3" sides together and have a sealed point. However the cutting got to be too much right from the start,, so I went with Plan B. I cut out the "mouth" by making two cuts 3" back from the open end, as close to the top and bottom (3" side) as I could on each side. Then I cut out the rectangle. I then bent the "lips" together and welded them with 1/8 7014. I'm sorry,,, that is probably not very clear. I will try to get a close-up picture of the points and it should be easier to see.
I think the fork will hold much more than my loader bucket will support. I welded an additional piece to the bottom of the bucket under each clamp, but it still feels flimsy when I pick up a full load (the bucket, not the fork). The fork is really rigid. I think 2x2 tubing, maybe 1/8 thickness might have been plenty strong enough. Just my inexperienced opinion.
Old 05-29-2010, 06:10 PM
Charlie C's Avatar
More STEAM!!
Pretty nice work,Nctox.
Old 05-30-2010, 11:43 AM
nctox's Avatar
SFT Navigator
DrBob,
I took these pics today; they're a little better than the first ones.
They show the "mouth" cut on each side, then the bent "lips" welded together.
I started to prime it, but the rain put a hold on it, so it'll get done later.
ID:	61507   Click image for larger version
ID:	61508   Click image for larger version
Old 06-01-2010, 02:32 PM
DrBob's Avatar
Default The pictures did the trick
As usual, the pictures are worth 1000 words! Nice, simple solution. I'm somewhat proud that I also came up with the idea of cutting a triangle out of the sides of the tines. Nice work!
DrBob
Old 06-01-2010, 03:31 PM
nctox's Avatar
SFT Navigator
Thanks for all the compliments. I'm new to this kind of thing, but I think I'm hooked!
