Old 04-05-2010, 12:28 PM
Bender's Avatar
Bender Bender is offline
One Lone Sub
Default The box blade
I've just about completed the box blade. A big thanks to soarkrebel for the plans. I followed them pretty close and adjusted as needed. I have 3 decent scrap yards within 7 miles of me so I lucked out and found everything I needed. All told, including nuts, bolts, and pins I think I have $250.00 into it.(not counting consumables)
1. I found a 4x5x3/8 piece of tube steel. My little saw cut it, but it took 33 minutes
2.and 3. I marked out the slots for the scarifiers and cut them with the plasma cutter.
4. and 5. Decent scarifiers are close to $40.00 apiece so I made my own.
Name:	Blackberry Pictures 318.jpg
ID:	59498   Click image for larger version
Name:	Blackberry Pictures 320.jpg
ID:	59499   Click image for larger version
Name:	Blackberry Pictures 321.jpg
ID:	59500   Click image for larger version
Name:	Blackberry Pictures 323.jpg
ID:	59501   Click image for larger version
Name:	Blackberry Pictures 325.jpg
Boise Paint Contractor
Facebook
How fortunate we are!
Old 04-05-2010, 12:38 PM
camdigger's Avatar
Roving Reporter
Looks good so far!
Do you have any plans to hard surface the ripper teeth? If so, I'd lean toward doing the leading face, so the material behind would wear away and make them self sharpening.
I didn't notice if the cutter bit ends up at an angle? For efficient action, I'd think you need 30 - 45 degrees.
Old 04-05-2010, 12:40 PM
Bender's Avatar
One Lone Sub
Digr suggested a brilliant way to cut the 3 x 1/2" steel. I did just like he said and cut a slot across the center, leaving about 3/8th on either side.
1. The only measurment I messed up was the first one The box should have been 20" tall and 24" deep. Somehow I cut the plate 20x20. Dang math
2. The cuts across the center.
3. The first bends.
4. Me
5.The second bends. I was really pleased they both came out so close to each other. Thats the beauty of Digr's idea.
Name:	Blackberry Pictures 352.jpg
ID:	59503   Click image for larger version
Name:	Blackberry Pictures 353.jpg
ID:	59504   Click image for larger version
Name:	Blackberry Pictures 354.jpg
ID:	59505   Click image for larger version
Name:	Blackberry Pictures 356.jpg
ID:	59506   Click image for larger version
Name:	Blackberry Pictures 358.jpg
Facebook
Old 04-05-2010, 12:43 PM
Bender's Avatar
One Lone Sub
No camdigger, they're flat on the bottom. I'm planning on putting the ripper tips on. I had to guess at the angles though so I hope it works.
Facebook
Old 04-05-2010, 12:51 PM
Looking good there, Dan.
Old 04-05-2010, 12:55 PM
Bender's Avatar
One Lone Sub
1. The first rough fit.
2. Drilling the first of a lot of holes. Starting with a 1/4" bit and stepping up to a 3/4" was the best way to do it. A lot of bit changes but worth it.
3. and 4. Again, I'm amazed at how well I could duplicate the bends. Pretty slick Digr
5. I welded the cuts with 7018. Root pass and then a nice big bead on top.
Name:	Blackberry Pictures 360.jpg
ID:	59508   Click image for larger version
Name:	Blackberry Pictures 361.jpg
ID:	59509   Click image for larger version
Name:	Blackberry Pictures 362.jpg
ID:	59510   Click image for larger version
Name:	Blackberry Pictures 364.jpg
ID:	59511   Click image for larger version
Name:	Blackberry Pictures 366.jpg
Facebook
Old 04-05-2010, 01:00 PM
Bender's Avatar
One Lone Sub
Thanks cutter. I have a few little things left to do to it then I'll post a few more pics.
Facebook
Old 04-05-2010, 11:53 PM
Dave Lee's Avatar
Dave Lee Dave Lee is offline
Armchair Webbie
Nice work, Bender. Did you have to weld the slits closed, from both sides of the bend or just one?
Dave
Old 04-06-2010, 12:29 AM
Pyro J's Avatar
Pyro J Pyro J is offline
Hearts on Fire
Those slotted/welded bends turned out really well.
Looking good Bender.
Old 04-06-2010, 08:19 PM
soarkrebel soarkrebel is offline
Looks good....glad I could help.
