Old 01-20-2010, 10:29 AM
digr digr is online now
Default Jacks
I know I posted these before in my hand tapper thread but I am posting them again because I find more uses for them all the time. I use them on the mill and weldments when you need a extra hand. These have 3/4" bolts. OOPS I already had a post on jacks
ID:	55958   Click image for larger version
ID:	55959   Click image for larger version
ID:	55960   Click image for larger version
Old 01-20-2010, 11:52 AM
Setup boy's Avatar
Setup boy Setup boy is offline
Press One for Trash
Jacks are just as useful as belt grinders and Lord knows we got lotsa belt grinder threads
Thank you,
Tom(Reformed Post Whore)
This legislation will have the effect of addressing that mal-distribution of income in America."
Sen. Max Baucus Montana
Do you want it right or right now?
Ya can't polish a turd.
The Techie Geek Podcast
Old 01-20-2010, 12:27 PM
ken98k's Avatar
ken98k ken98k is offline
You must be psychic; I was just looking at some of these last night in the Grizzly catalog and thinking how easily they could be made.
Old 01-20-2010, 12:38 PM
Digr,
those jack's are quite handy.
Now to make them nicer:
Chuck the bolt in the lathe (collet preferably)
and spot a center drill on the head.
Using a 1/2" dia. drill bit, put a 3/8"-1/2" dia.
spot on the head of the bolt.
Use a ball bearing between the head and your work,
the ball will sit nicely in the "divot" and make cranking
the jack much easier (part and jack will not "walk")
Even if you braze a ball up top there (to keep from falling out)
it will work.
Old 01-20-2010, 05:05 PM
Digr,
Do you use a lock nut, to hold the height when you get it set?? I'd think that vibration would cause the jack to loosen up without some sort of lock. Looks like a good idea and well done will have to think about making some.
Jack
Old 01-20-2010, 06:07 PM
Digr,
it will work.
'Good idea!!
Old 01-20-2010, 06:09 PM
Digr,
Jack
I sometimes use a jam nut on them.
Old 01-20-2010, 10:03 PM
OLD MAN's Avatar
OLD MAN OLD MAN is offline
2-3-1940 to 3-8-2011
Nobody was faster
Nearly all construction pipe fitters use a jack similar to that. Some are short and some are 2 or more feet long. When lifting pipe to square they cut a pipe smaller than a long stud and use one of the nuts on the stud to make it longrer. Sometimes there will be a pile for all fitters to use from. After the flanges are made up permenant pipe holders are made.
Old 01-21-2010, 07:34 AM
7018's Avatar
7018 7018 is offline
Nice job as always digr! Hay long time know see......
This post brought to you by the bringer of chaos, doom, change, and technology... Asker of questions, challenger of assumptions, solver of problems and share-er of ideas
Old 01-21-2010, 09:25 AM
I'll keep my eyes open for a few large threaded rod coupling nuts to make some of these.
