Old 12-17-2009, 08:47 PM
Default Harbor Freight # 97686 Desiccant Air Drier
Today, I had to run some errands, and ended up about a block away from Harbor freight. I went in looking for and found the model #97686, desiccant air drier, $40, and #97924 for the 2.2#bag of desiccant, $5. The drier is a 32" long piece of 2" pipe, with 2 removable baffles and about 24" of desiccant between them. The air enters in to a water trap, then flows thru the first baffle, up thru the desiccant, then thru the second baffle out of the drier. I bought this to run the air thru for the the plasma cutters. I've been using the smaller inline units, they work great, but don't last very long. Hopefully this will work, for what I got, I thought the price was very good.
Name:	desiccant dryer 001x.jpg
ID:	54282   Click image for larger version
Name:	desiccant dryer 004x.jpg
ID:	54283   Click image for larger version
Name:	desiccant dryer 007x.jpg
ID:	54284   Click image for larger version
Name:	desiccant dryer 010x.jpg
Old 12-17-2009, 09:15 PM
panhandle_redneck's Avatar
panhandle_redneck panhandle_redneck is offline
Definately let's us know how it works please.
I hear and I forget.
I see and I remember.
I do and I understand. --Confucius
Old 12-17-2009, 09:20 PM
Looks interesting! How do you change the desiccant? Could you draw it up so we can see how the baffles assembled?
Old 12-17-2009, 09:25 PM
Greenbuggy's Avatar
Greenbuggy Greenbuggy is offline
Send a message via AIM to Greenbuggy
how much is this advertised to flow?
I've got a sharpe dessicant dryer right now that I like - it gets the air VERY dry, but when hooked to my sandblast cabinet it seems like it gets bogged down quickly, I know part of this is the air supply up to the sharpe dryer, but the sharpe dryer has a sintered bronze element to keep the small dessicant particles out of the outlet hose, and I don't think it flows as well as it could.
Also, I'm curious if the mounting is required to be vertical? I don't have much free wall space in my shop.
Don't try this at home - UNLESS you live in a HOSPITAL!
Old 12-17-2009, 09:52 PM
200 degrees in the oven on a cookie sheet till the color changes back and you are good for reuse.Probably good for 3-4 hours of use before needing recharged ,at least that is all I get on the soda blaster.
Old 12-17-2009, 10:25 PM
I real sorry the attached picture is real crude
the 2 screw on caps, - Green
the main body, - black
the 2 baffles, - blue
the media area, the red between the baffles
to change the media, you unscrew the caps the baffles and media will come out. to reload, screw the bottom cap (with the drain) drop in the bottom baffle, load the media, install the top baffle, tighten top cap.
17 cfm @ 150 psi, the paperwork only talks about vertical mounting, probably because of the water trap.
Jack
Old 12-18-2009, 08:41 AM
Review Manager Review Manager is offline
Thank you Platypus20 for the submission of your review. You can now find it listed under the Harbor Freight location in the Product/Equipment review section.
Old 12-18-2009, 09:31 AM
tnmike's Avatar
tnmike tnmike is offline
Sultan of Scrounge
What was your main purpose for in buying this? I am assuming paint..
Klaatu barada nikto
Old 12-18-2009, 10:06 AM
flametamer's Avatar
Plasma cutters.
Dt
Sero Sed Serio
Old 12-18-2009, 10:16 AM
Like Cutter, I avoid paint or painting at all cost, unless I can paint outdoors. I run the plasma cutters constantly, and got tired of using the inline desiccant filters, at about $7/ea, so I went to this. Keeping the moisture levels as low as possible is the best way to prolong plasma cutter consumable life. It can be used not only with the plasma cutters, but any other air tool or air operated equipment I have.
