Old 05-02-2009, 11:48 PM
the spyder's Avatar
the spyder the spyder is offline
Default Craigslist drill press- Montgomery Ward Variable Speed
I found a too good to pass up deal on Craigslist today and sadly I missed it. However my darn eyes got my wallet in trouble again as I found another one. It was quite the adventure just to get it. Someone lost the keys to my truck, had to borrow a friends that lost 1 tire on the way. I finally made it there and found this: 17" Montgomery Ward (Powr Kraft) 2437 B Variable Speed 500-21000 RPM 9.0amp drill press. It was in good shape, ran true, and over all needs only some minor maintenance. It does have one problem, the knob for the speed adjustment is missing. I hope I did not buy a boat anchor as I can not find ANYTHING about this model online!
Was it worth the $80?
I need a new chuck for it if anyone has a recommendation or how to get what size of arbor/ect I need.
The one I missed was a Craftsman Professional with XY milling table. Looks to have weight 200 pounds easy. $250 with a 10" Craftsman table saw. Missed it by 20 minutes .
ID:	45406   Click image for larger version
ID:	45407   Click image for larger version
"Insatiable challenge!"
Old 05-03-2009, 04:29 AM
OLD MAN's Avatar
OLD MAN OLD MAN is offline
2-3-1940 to 3-8-2011
Nobody was faster
Looks like a good deal. I think it is twenty one hundred and not twenty one thousand. Take a photo of the chuck or the quill where it is missing and we can get started, usually the arbor is removable with a drift and then you can determine what size arbor you need. Also add a model number and maybe someone can find something about it.
Old 05-03-2009, 07:27 AM
500 rpm as a minimum speed is awful fast, if your main use is going to be steel, its okay for wood, if you are doing steel, hole saws and larger bits want to turn alot slower. This will burn up bits very fast. The rotating head is a nice feature.
Old 05-03-2009, 09:53 AM
TriHonu's Avatar
TriHonu TriHonu is offline
Look at the 2d picture the label states "17 inch Drill Press Router Shaper" and the numbers on the lower half of the speed dial appear to have 5 digits.
Definitely designed for wood working. Even if you don't want to keep it, I'm sure there are wood workers who would love to have a machine like that in their shop.
$80 for a floor standing drill press is pretty cheap in my part of the country, especially for a variable speed model. I think you got a great deal. I would think you could sell it for more than you paid by describing it as multi-use wood working machine.
Old 05-03-2009, 12:14 PM
the spyder's Avatar
I think it will end up at my fathers new wood shop. I was looking for something 200-300rpm since I want to be using it for steel and aluminum.
Old 05-03-2009, 12:47 PM
RancherBill's Avatar
there has to be an answer
Well I think you Father SUCKS. :evil:
1) great price - free, because of all the nice things he's done over the years.:evil:
2) ton of features - variable speed and routing
3) free delivery.
:evil::evil:
Old 05-03-2009, 04:16 PM
Vegas Sparky Vegas Sparky is offline
if the unit is belt driven you may be able to change out the pulleys on it to get lower speeds. it may be worth checking out.
Old 05-03-2009, 08:37 PM
Brian C.'s Avatar
Brian C. Brian C. is offline
Director of Security
Missing speed adjustment knob- think golf ball. They worked on the old man's craftsman for years.
Millermatic 211
Harris oxy/act.
2 propane forges
147 lb. Peter Wright anvil
Old 05-03-2009, 08:58 PM
the spyder's Avatar
No belts- straight solid state controller.
Old 05-09-2009, 05:12 PM
Uncle Buck Uncle Buck is offline
Check Grainger, they sell knobs and stuff like that.
