Rest In Peace Cutter
Old 10-05-2008, 12:36 PM
Default Retractable caster
This little bench started it life when I rescued it out of the dumpster. I needed a little bench one day and brought it in, I had a piece of half inch plate for the top but the bench was a tad short so I welded four pipes to the top and welded the plate to the pipes. By accident it worked well, a place to place tools and what not and good clamping ability. I have been dragging it around for a couple of years now so I decided to put casters under it. But with casters it seems like no matter what you do only three hit the floor. So I came up with this idea. I use a 3/4" pipe to slide over a stub shaft welded to the main shaft to roll the caster over center when I need to move the table and bring it back down on to the threaded rod when using it. If anyone uses this idea on a bigger bench you might want to use two casters instead of one.
ID:	36651   Click image for larger version
ID:	36654   Click image for larger version
ID:	36655   Click image for larger version
ID:	36656   Click image for larger version
Old 10-05-2008, 12:37 PM
More pics
ID:	36658   Click image for larger version
Old 10-05-2008, 12:52 PM
OLD MAN's Avatar
OLD MAN OLD MAN is offline
2-3-1940 to 3-8-2011
Nobody was faster
A good answer to a common problem. Good job.
Old 10-05-2008, 01:22 PM
Cool deal, digr. As usual.
Shocking lack of paint, though.
Old 10-06-2008, 12:33 PM
MangleWeld's Avatar
MangleWeld MangleWeld is offline
Thumbs up
Neat setup nice work I'll take one!!
The gene pool could use a little more Chlorine.
Speak softly But carry a Big Stick
Don't pick a fight with an old man. If he is too old to fight, he'll just kill you...
If you don't VOTE you don't COUNT!!!
Old 10-06-2008, 02:24 PM
Hmmm, just how big would the castors have to be if they were placed on the rear of my Toy to ease the problems associated with short spaced parallel parking?
Old 10-06-2008, 08:28 PM
Jeff's Avatar
Jeff Jeff is offline
Big Iron
Great work as usual.
Jeff
