Old 04-26-2008, 08:01 PM
joeywrench joeywrench is offline
Default plant shelf
got some 1/2" box steel from home depot and a few 1x2 pine pieces.
i bent the 1/4 inch rod around a 5 gallon bucket while someone sat on it.
i need to make one more for the other window.
total cost was under 20.00
ID:	31389   Click image for larger version
ID:	31390   Click image for larger version
ID:	31391   Click image for larger version
ID:	31392   Click image for larger version
Old 04-26-2008, 11:03 PM
MrRodeoCC MrRodeoCC is offline
Good Job, I like the way the wood carries through to the deck outside.
Woodworker Enthusiast, Welder Newbe
Hobart Handler 140, 4 1/2" B&D Grinder, HF 4 1/2" Grinder.10" Table Saw, Drill Press, Compound Sliding Miter Saw, Planer, Joiner, Routers, Wood Lathe, other misc saws and tools, clamps galore
Old 04-27-2008, 12:41 AM
That's a nice looking little shelf, Joey. Are those braces pinned to the wall or just resting against it?
Old 04-27-2008, 06:50 AM
just resting. i didn't want flat brackets or screws there. and i never noticed how it runs with the deck outside. good observation.
Old 04-27-2008, 12:36 PM
I mount a lot of my shelves that way, secured at top and rest on the sides, my vertical pieces usually rest over the studs running beside the window so the sheet rock is supported, no need for screws through them then. Less holes to fill in the future. The wife changes decorations too much, lol.
Old 04-28-2008, 10:57 AM
madam X's Avatar
madam X madam X is offline
One Wonderful Lady!
That's a handsome shelf!
Rated M for MAGA
Old 04-28-2008, 11:35 AM
Team DeSade's Avatar
Team DeSade Team DeSade is offline
Send a message via AIM to Team DeSade
Nice idea. I may have to build up something like that for the cats.
Terry
Old 04-29-2008, 08:00 PM
Garth's Avatar
Garth Garth is offline
Thumbs up
Nice shelf.
miller 301g mig tig high freq, sp135 spectrum 375, delta band saw drill press, mag drill, belt disk sander bench grinder mm251, OA, 1 welding truck,
Old 04-30-2008, 08:20 AM
Simple and elegant, now if I can get her to water them......
Aaron Neville
