Old 03-13-2008, 09:10 PM
Default Jet JVM 836-1 Jet Milling Machine
The second half of the Jet DP and Mill package, I talked about in the JDP-20EVS/230 thread, is the Jet JVM 836-1 milling machine. This is a small floor standing knee mill, with a 8" x 36" table, a 1 1/2 hp drive motor thats either 115/230 single phase, with a R-8 spindle taper. Its a v-belt and pulley drive system, with 5 speeds, 240-1550rpm, I made a secondary "transmission", that increases the number of speeds to 25, 80-1800 rpm. I also wanted a greater spindle to table spacing, so I installed the 4" riser block, a Grizzly product (H8107) for their G6760, milling machine, which is identical to the Jet. When I purchased the mill and DP, I had been looking for a Bridgeport type mill for over 3 years, with no luck, when the package deal came through, I grabbed it. The mill was a completely manual mill, since I have owned it, I've also installed X, Y and Z power feeds. Is it a perfect mill, no, but its far better than anything I found in my 3 years of looking, I have a bigger mill in storage, but until I get a bigger tool closet, this will have to do. I'm very happy with the mill and the 2 Jet DPs I have, and would not hesitate to buy another Jet product. Again the cost for the base unit is about $3500.
Jack
http://industrial.jettools.com/Produ...12&Part=690036
Name:	jet mill 001.JPG
ID:	29638   Click image for larger version
Name:	jet mill 002.JPG
ID:	29639   Click image for larger version
Name:	jet mill 006.JPG
ID:	29640   Click image for larger version
Name:	jet mill 010.JPG
ID:	29641   Click image for larger version
Name:	jet mill 008.JPG
Old 03-13-2008, 11:35 PM
Is that spacer hollow/cast ?
Old 03-13-2008, 11:59 PM
KB Fabrications's Avatar
KB Fabrications KB Fabrications is offline
Member Emeritus June 1965 - August 2015
Looks like it.
I've been crawling on my belly, clearing out what could've been. I've been wallowing in my own chaotic and insecure delusions. I wanna feel the change consume me, feel the outside turning in. I wanna feel the metamorphosis and cleansing I've endured within.
My shadow. Change is coming. Now is my time. Listen to my muscle memory. Contemplate what I've been clinging to.
Maynard James Keenan
Last edited by cutter; 03-14-2008 at 01:00 AM. Reason: cleaning up after greasePit habits
