#41
![]() Rick
if it aint broke fix it till it is Proud member of the garbage gang and sub chapter Mole Hill gang ![]() Politically Correct : A term used for whiny pu**ies that need sh*t sugar coated . |
#42
http://blacksmithnews.com Side Blast Forge Peter Wright Anvil Lincoln AC/DC 225 Buzz Box 4"x7" Horizontal Band Saw Grizzly Drill Press |
#43
Used off & on for the last 30-40 yrs
#44
Some people will advocate getting a cheapy HF anvil instead of using rail. They feel that the rail does not provide enough mass to move metal. I guess it would depend on how thick of metal you are working, and how often you want to use it, plus what you are securing the rail to, and how heavy that is. I would probably go with the HF anvil over rail, then look at upgrading to a better anvil after your skill improves. Sometimes it can take a good while to find a decent anvil as well.. Although if the rail is free then it's price sure beats HF.
#45
I'm still going to check it out, I just figured with it lying partially buried,no air, and wet conditions in the ground that it maybe severely rusted and pitted up. I guess I was hoping he had it resting up on a couple 4x4 post or something, up off the ground. I hope I'm wrong about the rusting out,sure wouldn't be the first time.
![]() I have seen the HF anvils and considered one them also, I just thought it would be cool to have one of the homemade rail anvils, someone looks at it and you could say "yeah!" I made that ![]() I'll have to read cutters vise through out. ![]() Tony
John 14:6 KJV Jesus saith unto him, I am the way, the truth, and the life: no man cometh unto the Father, but by me. |
#46
Don't let a little rust pitting slow you down. Once you get it roughly torched into the shape you want.... Grind & sand it to the final shape and finish you want. Go all the way to good metal and it will be impressive. Not to mention honing your skills at metal finishing. ![]() |
#47
FWIW have you looked at the import jobs from Grizzly?
http://grizzlyindustrial.com/product...s.aspx?q=anvil
The definition of courage. "It's when you know you're licked before you begin, but you begin anyway and you see it through to the end no matter what." From "To Kill a Mockingbird" |
#48
#49
There is a fun read here, about making your own anvil. Don't think I'd want to do it, but its a fun read none the less.
#50
That's the link I was looking for but couldn't find. Thanks!
