Old 11-22-2007, 09:37 PM
Pat's Avatar
Pat Pat is offline
Default Cutter...Need Port-A-Band Info
Cutter,
I remember reading your post about your new Harbor Freight portaband saw, and the modifications you made to it. I was wondering if you could tell me how well the saw has performed for you, and if you would recommend that model over a name brand unit if the saw would see limited use.
I was all set to buy a Milwaukee model because I generally like to buy quality tools even if they would not be heavily used. But after using the new Milwaukee portaband at work, I wonder if the extra money would be worth it for me. This new Milwaukee cut through some 2" .250 wall square tube really good, but for some reason the blade kept coming off. As far as we could figure there is no way to adjust the tension on the blade other than just flipping the lever after you put the blade back on. We even tried a couple of other blades thinking the blades may be defective, but no luck.
So if the Harbor freight will hold up to occasional use, I think it would make more economical sense for me to go this route. I would appreciate an update on your saw experiences..........thanks,
Pat.
Old 11-22-2007, 09:41 PM
Cavalry's Avatar
Cavalry Cavalry is offline
Below Wholesale
I would try a different blade from a different mfg. I have a milwaukee and it preformed flawlessly untill the rubber bands wore and I cut though the stop. Couple reasonable parts and she operated like new.
Old 11-22-2007, 09:54 PM
Pat.
Pat, other than it being so cheaply built and ugly as sin I simply cannot complain about it. It kinda gives you that "Oh NO!" buyer's remorse when you see the plastic wheels & things like that but the silly saw has cut every thing I've tried. Like you said, I only use it occasionally and when nothing else seems to fit but I do not regret the purchase.
Now, I do keep it sort of hidden so nobody else ever sees it.
Old 11-22-2007, 10:28 PM
1911man's Avatar
1911man 1911man is offline
Co-founder, Harbor Freight 12 Step Program
Pat,
I have the same saw and followed the procedures Cutter laid out. I am satiafied with the saw but have not used it a great deal. I think it's a good value for a hobbiest like myself but it might not hold up to harder, more frequent use. Whatcha want for 60 bucks
The older I get the more I know and the more I know the less I understand.
"I'll keep my freedom, my guns and my money. They can keep the change."
Old 11-22-2007, 11:03 PM
platypus20 platypus20 is online now
Cutter,
Could you please, either describe the mods, or direct me to the link, so I can read about them? First I didn't know that HF sold a porta-band, second what kind of problems necessitated the need for the mods. I have 2 of the MIlwaukee porta-bands and beat the ever living dogsnot out of them (10-15 hrs a week, cutting boiler tubes and angle iron), and like a Timex, they just keep on ticking. The only other porta-band I've ever seen has been a Bosch.
Jack
Old 11-22-2007, 11:14 PM
Sure Jack, Here you go.
I really didn't do any modifications so much as finish assembling the derned thing.
But I did show the insides.
Old 11-24-2007, 10:17 AM
rustybearing rustybearing is offline
Hey Pat. Here's mine with a stand I made. The base is from an old Ryobi band saw and I'm on blade number 6. I use it a lot but I take it easy because I know it's HF. I got mine on sale for $69. Jim
ID:	24892   Click image for larger version
