Old 10-21-2007, 11:04 AM
Default Hand tapper
I always wanted one of these so I started one. It will take long time to finish so I thought I would put in installments. I know you can buy one for 80 dollars but what would be the challenge in that. The first step was the drawings but they changed on the way out to the shop. This post is on the table. Lots of pictures so I hope you can suffer threw them. I made a copper wedge to keep weld out of the slots when welding the sides. This is the first and only thing I have made is the table so far. The pictures were in order before the crash of 2007 but now they are not because of a little to much vodka. Thanks for looking!
ID:	24826   Click image for larger version
ID:	24827   Click image for larger version
Name:	plug weld 1.JPG
ID:	24828   Click image for larger version
Name:	bottom plate.JPG
ID:	24829   Click image for larger version
Name:	plug weld 3.JPG
Old 10-21-2007, 11:08 AM
Default Table
Table pics Table size is limited to lathe size.
Name:	FRONT drawilng.jpg
ID:	24831   Click image for larger version
Name:	SIDE drawing.jpg
ID:	24832   Click image for larger version
ID:	24833   Click image for larger version
ID:	24834   Click image for larger version
Old 10-21-2007, 11:12 AM
Default Table
More pics
ID:	24836   Click image for larger version
ID:	24837   Click image for larger version
Old 10-21-2007, 11:29 AM
Paychk's Avatar
Paychk Paychk is offline
Project Phoenix
Lookin sweet!
Ory-gun Boy!
Old 10-21-2007, 11:30 AM
Lots of pictures so I hope you can suffer threw them. Thanks for looking!
I love your project threads, digr. We shall endeavor to persevere.
Old 10-21-2007, 11:56 AM
SlimJim's Avatar
SlimJim SlimJim is offline
Founder: Machining Forum
Digr, can you post those files up in a dwg format?
Director of Purchasing
Tact is for people who aren’t witty enough to use sarcasm.
Old 10-21-2007, 02:30 PM
Cavalry's Avatar
Cavalry Cavalry is offline
Below Wholesale
Pretty neat how you built up the table for the t-nuts.
The suspense is killing me, so I must ask how you intend on making the spindle perfectly perpendicular to the table. Looks like it might be kinda big to be floppin' around in the lathe?
Old 10-21-2007, 06:26 PM
Default Drawing
Is this what you wanted SlimJim? By no means was I this critical with the measurements but this is the measurements I was going after. I used 3/8" bolts as spacers and just spread the flat bars apart just a tad for clearance. In the pictures I allowed 1/4" all the way around but found that it was a bit much, 1/8" would be just right.
Old 10-21-2007, 09:16 PM
Walter Svandrlik Walter Svandrlik is offline
I was planning on building one of those when/if my shop gets finished. Thanks for doing all the figuring and planning. Thanks
Doing things normally is greatly overrated
Old 10-21-2007, 10:17 PM
Gadgeteer's Avatar
Default Hand Tapper
Geeesh... just when I think my list of projects is narrowing, digr does it again.
Thanks a lot, buddy.
