Old 02-14-2007, 08:15 PM
digr digr is online now
Default Axle extend
This is at work. We had a conveyor that we had to put a new axle under with air brakes. The new laws are getting quite strict. First I cut and beveled the new axle and burned holes for plug welds then inserted a smaller tube into the axle housing then slid a larger tube over the insert. This is a little overkill but it doesn't hurt. Left a 1/4" gap between the tubes then leveled and tacked it up and welded it out. I did verticals on the core beads to assure all three pieces were welded at the same time. We added new bearings, breaks, tank and landing pads for the pipes on the conveyor. Next we rolled under the conveyor and measured from the center of the pintle hook and welded it to the pipes on the conveyor. The height of this conveyor is adjustable with square tubes welded on the conveyor and pipe welded to the axle. This works great in the gravel pit environment never any binding.
ID:	20404   Click image for larger version
ID:	20405   Click image for larger version
Name:	tube incert 3.JPG
ID:	20406   Click image for larger version
Name:	outer tube 4.JPG
ID:	20407   Click image for larger version
Old 02-14-2007, 08:20 PM
Installing
ID:	20409   Click image for larger version
Name:	Tank Brakes 7.JPG
ID:	20410   Click image for larger version
Name:	Under conv. 8.JPG
ID:	20411   Click image for larger version
Name:	Welded R 9.JPG
ID:	20412   Click image for larger version
Name:	Welded L 10.JPG
Old 02-14-2007, 09:05 PM
Jeff's Avatar
Jeff Jeff is offline
Big Iron
Nice work on the axle.
Wow, new cans and slacks, New Superior rollers, You've been having some fun.
But,, do I see a bow in the lattice frame?
Jeff
Old 02-14-2007, 09:07 PM
King of Obsolete's Avatar
Published Author
very nice job, even new brakes, wow eh!!!!!
thansk
King of Obsolete
Cat Train Tours
Old 02-14-2007, 09:19 PM
Ya We built about 1000 feet of conveyors about 15 years ago including stacker's and transfers and other conveyors for two closed circuit jaw and cone crusher spreads and they have been threw a lot. Last year this one had 750000 tons over it and the year before a million so they are bent a little here and there.
Old 02-14-2007, 09:20 PM
thansk
Thanks King
Old 02-14-2007, 09:27 PM
Jim-TX's Avatar
Jim-TX Jim-TX is offline
Chairman of the Headboard
Nice work and pics. That tire in one pic looks like it has a couple of miles on it.
Old 02-14-2007, 09:46 PM
Thanks Yes it does, off the trucks and onto the convayers but yes that one looks like its close to the rub bars.
Old 02-14-2007, 09:57 PM
Charlie C's Avatar
More STEAM!!
Very nice job Digr. I enjoy doing stuff like that but not if I have to do it for a living. It than becomes work.
