![]() This is part of a set of trucks that I made to handle a piece of new equipment in the shop. The beam is made from L 2x2x1/8 steel. After painting with spray can enamel it was decided to add a handle made from 3/4” steel tube. Check out the perfect circle left in the burned paint on the opposite surface of the weld. Has anyone noticed this before? No machining or processing of any kind was done here prior to welding.
Rust is a color too. |
I think you painted over a round sticker and didn't notice it until you roasted it with the welder.
I am compelled to run a test to see if I can duplicate this phenomenon.
OR, somebody welded in a hole that was in the metal and ground it flat? Get testing because we need to know...
Perhaps some of you fellows think I am effing with you? I assure you I am not, this really did happen as I described.
I'M not farking with you, those are actual theories I have put forth. I think it was a sticker or sticker residue that reacted when heated. Coincidental it aligned with your weld.
C clamp?
Drawing by Smartdraw |
Its a sign from god,i think its his picture,or maybe somebody else?
Bingo!
The Wilton clamp I used has a near perfect round stationary jaw face.
