Old 10-31-2008, 07:30 AM
OLD MAN's Avatar
OLD MAN OLD MAN is offline
2-3-1940 to 3-8-2011
Nobody was faster
From post #2 try spinning and add power.
Old 10-31-2008, 08:13 AM
O'man, that jogged a question I've had. Just how much rpm does an electric motor have to have before the run capacitor has the fun and the start cap is finished?
Old 10-31-2008, 10:08 AM
Bender's Avatar
Bender Bender is offline
One Lone Sub
Originally Posted by Cutter
Wayne blew the sawdust out of the starter switch
Ohh, thy cruel irony.
Good luck Tommy. Don't know if it helps but I have the same motor on mine.
Boise Paint Contractor
Facebook
How fortunate we are!
Old 10-31-2008, 10:09 AM
Lu47Dan's Avatar
Lu47Dan Lu47Dan is offline
Connoisseur of Old Iron
Tommy , the motor on my table saw hummed also turned out to be the switch itself . The cap was good but the contacts in the switch were bad . Dan
Miller XMT-304 Multiprocess
Miller 10-E Wire Feeder
Hobart AC/DC stick welder
Hobart 175 Mig
Craftsman O/A set
Turbo torch and B-tank
Old 10-31-2008, 10:50 AM
boilerman's Avatar
SFT Brewmaster
Originally Posted by TommyA View Post
I get 122 volts at the motor on both posts so the switch is working. It is 230 Volt motor however I'm not sure of the HP. .
the HP. rate of SPL is just some marketing BS....it is a 5 HP motor
amps x volts=3300....divide by 745= 4.43hp.....5hp for 220volts
amps x volts=3600...divide by 745=4.83hp....5 ponies in it for 240volts
Old 10-31-2008, 10:54 AM
I get 122 volts at the motor on both posts so the switch is working. It is 230 Volt motor.
Ok. but are you reading 240 across the lines/wires ?
Old 10-31-2008, 02:48 PM
TommyA's Avatar
TommyA TommyA is offline
Director of Product Reviews
I'm getting 123 volts on each side coming from the switch but I don't get a reading when connecting to the two side at the same time. I don't think that I should. Should I?
LW according to the Pentek page you so graciously provided the motor once reaching operating rpm should disconnect the start capacitor and use the run capacitor. so it looks as though I need to spin it at 3400 rpm to see if it will run off the run capacitor. Spin Spin
I'm disassembling the drive belt right now.
What Would Jimmy Buffett say?
since I was three feet tall.
Old 10-31-2008, 02:59 PM
One line is open.
Your just getting what comes around thru the motor and back to the other line.
Assuming your checking from ground.
If your motor is wired for 230 you should get 240 across the two wires.
Like I said in my first post reset your TWO breakers first !
Old 10-31-2008, 03:34 PM
Yes, you should be getting 240-something across the motor leads.
If the breakers are passing 240v across the lugs then I'm betting the pressure switch has a bad contact.
Old 10-31-2008, 04:46 PM
Photomask's Avatar
Photomask Photomask is offline
Big Stone
Smack the switch roughly with a screwdriver handle. You may have a bit of carbon buildup preventing the switch from making good contact.
