Old 03-30-2015, 01:01 PM
EvoIron EvoIron is offline
These two containers are the basis for a confined space training prop. The added roof support is so several people and equipment can setup for mock rescue situations. The original roof structure is not designed for more that a cpl ppl walking around and was kind of soft and bouncy. The other openings are all the same size so they can accept an insert frame with different size & shape openings on it. The second box (shown with some floor removed) is getting cut in two, with the larger piece going vertical to simulate a tank structure. As far as the wood floors go, removing just a few feet was the only pia part of this job and I figured it's treated with something nasty.
Sent from my iPad using SFT
Old 04-05-2015, 01:41 PM
Made a bit more progress yesterday. The long section will become the vertical tank simulator & the framework will have 3/16 sheet attached for decking with a center opening.
ID:	123378   Click image for larger version
ID:	123379   Click image for larger version
ID:	123380   Click image for larger version
Old 04-06-2015, 08:20 PM
DeepSeaDynamo's Avatar
DeepSeaDynamo DeepSeaDynamo is offline
Originally Posted by Dave Lee View Post
Kind of makes ya' wonder, how sound of an idea it is to use one of those things for a dwelling or even a workshop for that matter.
Dave
You're probably ok if you don't try to eat it or breath the saw dust. So I guess no pets or children.
Anyhow EvoIron you're doing a great job, looks like it'll be plenty sturdy!
