Old 07-22-2019, 02:19 PM
Scratch Scratch is offline
Default DIY Magnetic Chucks
Yesterday, I heard a little about using microwave transformers to make a DIY magnetic chuck for grinding small parts so I did a little bit of research. I also removed the 3 transformers from my junk microwaves.
I was happy at how easy they were to remove from all 3 microwaves first of all. I just removed the main cover and the transformer bolts were all easy to access. No need to dig into the deep depths of the microwaves.
But I was super happy at how easy they were to turn into electromagnets! The only hard part was removing the primary winding, and that wasn't too bad either! I even got them to work great using one AA battery! I put one battery on it then stuck a small piece of metal to the magnet. Then I used a flap disc grinder and a wire wheel grinder on it, pushing real hard, and the piece never moved. And that was with one AA battery! I also had a double battery bucket and hooked that up and it worked even better.
Then I hooked it up to my 18V drill battery and was shocked at the pull it had! Way more than I needed but still super cool!
My question is has anyone gotten these to work as small part holders and how did you power them?
Convert AC to DC with some extra electronics?
Just use Drill batteries?
Use 12V alarm batteries?
Stick with a couple toy batteries?
What about wiring? My AA setup wiring never got warm, but my 18V battery made my wires start to get warm and I'm not sure the best way to go about keeping them from getting too hot.
Any input?
Here's some pics, and if you want my advice... PULL THAT TRANSFORMER BEFORE YOU TOSS THAT MICROWAVE!
ID:	151584   Click image for larger version
Old 07-22-2019, 02:39 PM
astronut's Avatar
astronut astronut is offline
My magnets that I have pulled from microwave oven reactors. Self powered and no external power needed to make them work. I have pulled many from failed microwave ovens for myself and other owners and provided them with very strong magnets.
Lincoln Weld Pak 100
Giant Tech Arc 200
Miller Roughneck2E
Old 07-22-2019, 03:40 PM
Why didn't you just leave the primary windings?
Old 07-22-2019, 09:52 PM
JBFab JBFab is offline
If you do end up using power tool batteries, I saw these available for DeWalt 20v batteries. If you rig up your own the two outside pi s are + and - while the inner pins allow you to select lower voltages by only engaging certain series of cells - full disclaimer, I don't know how that would affect battery life.Click image for larger version
I think it was the secondary he removed. ( The high voltage for the maggie. I don't see any sign of the filament [pardon me Heater] winding either.) :-)
...lew... and old Radar maintenance S/Sgt. :-)
Old 07-22-2019, 11:36 PM
Dave Lee's Avatar
Dave Lee Dave Lee is offline
Armchair Webbie
Not to hijack this thread but, if you look on the youtube channel by poroldchap, he shows how to take those magnets and make one capable of lifting a small anvil. Also, I saw someone use a similar magnet as a demagnetizer by passing a screwdriver in and out of the hole. Without touching the sides, of course.
Dave
Old 07-23-2019, 09:48 PM
I guess you want the primary winding at the bottom of the base. The secondary winding is there. You need to pull the primary, then the secondary, then put the primary where the secondary was to get the most effect.
Old 07-25-2019, 05:27 PM
I would use mags from a electric brake system
Old 07-27-2019, 09:59 AM
Any input?
You need an amp meter to figure out how much power you need, if you do not know how to connect one search the net and find out.
batteries may not last that long and let the part go.
Ideally you may want both on a power failure.
