Old 07-19-2019, 10:58 AM
astronut's Avatar
astronut astronut is offline
I hope the gate works out for them. As you say Ironman, the bin may not be very large and the product may not put too much pressure on it to make it difficult to operate.
Lincoln Weld Pak 100
Giant Tech Arc 200
Miller Roughneck2E
Old 07-19-2019, 12:24 PM
Dr Dean's Avatar
Dr Dean Dr Dean is offline
no bull it's huge!
I'm betting this is going to work out just fine, I don't think I'd change a thing. A 10" trap in a grain bin isn't that bad to pull as long as it isn't rusty, It looks like you have some mechanical advantage.
The truck traps problem is moisture, dirt, and anything else that the tires could flip up there doing what it could to make it one solid piece of rust. In this area we use crushed limestone for our gravel roads. That stuff just as well be cement once it's been wet and dried. The dust gets into everything and guaranteed wherever it sits will be rusty underneath.
Old 07-19-2019, 02:55 PM
Originally Posted by moe1942 View Post
I hope they appreciate having the right man on the job....
Thanks Moe.
I took it over to them today, told the boss about SFT and the thinking that there will be an issue. He is certain that it will work, but can't install til Monday. The boss said they have air and would go with air power if they needed to.
He packed it up a ladder and test fit it, and they need to have the actuating shaft 8 inches longer to clear the side of the wind and screen machine, so I took it back and added that.
And they whipped up a check just like that....nice.
Old 07-20-2019, 10:56 AM
moe1942's Avatar
moe1942 moe1942 is offline
Voice of Experience
Thanks Moe.
It's hard to be humble when you're good...
Old 07-20-2019, 01:24 PM
Yup, Gerry has difficulties with that...
Old 07-31-2019, 09:02 PM
The feedback is that the plate valve was a success, and they sent over some machining work to do.
Old 07-31-2019, 09:23 PM
Are we running in reverse?
Old 07-31-2019, 09:42 PM
Sounds like you have a good new customer.
Woodrow Wilson
Old 07-31-2019, 09:57 PM
The cutter certainly looks it. :-) One of those carbide tipped boring bars . :-)
...lew...
Old 07-31-2019, 10:27 PM
Yeah I think Gerry is because he probably only has a RH boring bar. On occasion I have mounted a boring bar on the back side of the toolpost when I've got something fairly large diameter to turn. I did spend the extra bucks and buy a LH bar so I don't have to run the tool upside down...
