Old 06-03-2019, 01:38 PM
kbs2244 kbs2244 is offline
Isn't that thing going to need windows?
And,
Now that you are back, don't be a stranger.
Old 06-03-2019, 03:24 PM
King of Obsolete's Avatar
Published Author
....and yet...somehow....you are able to post onto the " World Wide Web"
as well as maintain a web page.....
it is how I see the world, lol.
thansk
King of Obsolete
Cat Train Tours
Old 06-03-2019, 03:26 PM
Published Author
Welcome back Joey. It's good to hear from you again.
I noted you repeated the phrase "at my age" and I can say welcome to the grey pack, it doesn't get easier and things don't heal any faster.
i'm not ready for shadey pines retirement home,,,yet. just working smarter not harder which took over 30 years to figure out.
thansk
King of Obsolete
Cat Train Tours
Old 06-03-2019, 03:27 PM
Published Author
And,
right now the brakes are more important then windows, lol
thansk
King of Obsolete
Cat Train Tours
Old 06-03-2019, 04:45 PM
Welcome back!!!! does it have outriggers?
Old 06-03-2019, 08:10 PM
Published Author
the Green Toy has 4 manual pull out riggers then you manually screw them down. but back when they design the out riggers they never thought of plastic sliders or grease nipples or any means of lubing up the steel on steel. I soaked the out riggers down and 3 weeks later after cutting 1/2 the slide tube away I was able to tug the 1 leg out then bunt the other one out. when re-assembled there will be means of lube in the form of grease nipples or oil holes.
thansk
Name:	GT leg pull.JPG
ID:	151031   Click image for larger version
Name:	GT leg push.JPG
King of Obsolete
Cat Train Tours
Old 06-03-2019, 08:26 PM
thansk
You'll probably get good setting them by swinging the boom over each one, shoving down to lift the truck and then spinning them down.
Lather
rinse
Repeat
Old 06-03-2019, 08:34 PM
Published Author
Lather
rinse
Repeat
most of the youtube videos show using the out riggers when doing a 20,000lbs lift. most of the time the out riggers are not used. fear and common sense is not a problem I guess, lol
thansk
King of Obsolete
Cat Train Tours
Old 06-04-2019, 12:01 AM
TEK's Avatar
TEK TEK is offline
Lather
rinse
Repeat
Could probably boom over and hook the bed on that side, pull the tires up off the ground
-----DozerDan
Old 06-04-2019, 05:46 AM
I thinking a set up of easy to handle tube to set up a pulley straight out from where outriggers have to slide, and then cable and pulleys to spot where can hook up to the winch and let the winch do the heavy pulling. Same for pulling them back in.
You will be able to figure something out. Just need to think outside the box, and a working idea will come.
