Old 05-15-2019, 11:26 AM
Originally Posted by JBFab View Post
I made a couple of press brake calculators in Excel that I've been meaning to clean up and put in PDF form. I'll try to get that done soon and post it to the forum.
One is a tonnage calculator, and one is for calculating how to bump a radius.
Sent from my SM-N960U using ShopFloorTalk mobile app
That would be very useful!
Old 05-17-2019, 09:00 AM
Here's a spreadsheet for bumping a radius.
I've never found a downloadable calculator for press tonnage, this one is as good as any.
Old 05-17-2019, 09:50 AM
Kinda hard to use these calculators when your in a scrap yard looking at a piece of die, and wanting to know if it will work for you....
8x material thickness
1/4" plate takes 20 tons per foot
Old 05-22-2019, 08:04 PM
Scratch Scratch is offline
Well, we went and ordered a kit. I have no mill so making one myself would have been more difficult, plus... I only paid 150 for it since I split it with my brother. Got it welded up a few days ago, then painted it and took a picture of it because everybody loves pics right!
I'm very happy with it so far. It seems to be very beefy, the instructions were clear, and it went together with no problems and very quickly. Should work great for what we need it for.
Old 05-23-2019, 05:55 AM
Old 07-09-2019, 09:29 PM
I still really like the Swag Off Road press brake, but I find myself needing to bend either thin gauge steel or smaller pieces of steel so I was thinking about ordering their Flat Top adjustable bottom V-die.
Then I remembered I have a CNC plasma cutting table and some extra 1/2" AR500 steel so I decided to make one instead.
If you don't know what a "Flat Top adjustable bottom V-die" is, here's the link:
http://www.swagoffroad.com/SWAG-20-T...Die-_p_94.html
I pretty much made a duplicate of that except my theory is "overkill is under-rated" so I beefed it up. I used AR500 steel, and used all 1/2" steel, instead of 1/2" and 3/8" steel that they used. I also added a support brace because I may have to bend Vibranium someday...
In the first pic you can see the parts I cut out. The part on the right is the main bottom plate and has a support brace that almost touches the bottom of the existing brakes V-die. The two parts in the middle make up the adjustable V-die. The two round pieces are spacers for the springs since it moves everything up a bit.
The second pic is getting ready to install the Flat Top in the brake.
The next two pics are of it installed, piece by piece.
ID:	151449   Click image for larger version
ID:	151450   Click image for larger version
ID:	151451   Click image for larger version
The next pic is with the Flat Top all installed, and the fingers of the press brake put back on.
And the rest of them are as it sits in the press.
I can adjust the spacing of the Flat Top to whatever I need to and still get nice clean, small radius, crisp bends in up to 3/16" steel, but I'll be using the Flat Top more for smaller thinner pieces.
Next up... I think I need an air hydraulic jack... bad!
ID:	151453   Click image for larger version
ID:	151454   Click image for larger version
ID:	151455   Click image for larger version
Old 07-09-2019, 09:54 PM
That looks "factory" to me, Scratch. Very nice.
Old 07-09-2019, 10:24 PM
pepi's Avatar
pepi pepi is offline
I agree and his parts look cleaner
Pep
*** KAG ***
Old 07-10-2019, 08:56 AM
JBFab JBFab is offline
Here is the press brake tonnage calculator I made - I had to take off the calculator for bumping a radius - I don't have the conversion to PDF done yet. But I figures something is better than nothing.
I tried to post it in General Technical Information, but it appears you need special permission to do so.
