Old 05-04-2019, 05:32 PM
Default Shop Mod
I had sliding barn style doors on the shop that was used to park equipment, RVs and boats. It has evolved imto a welding, and machining shop so no need for the sliding doors anymore. Also eliminates the 2" gap at the top of the sliding door that let all the heat out of the shop in the winter.
The new wall will be 10' wide and 14" tall. I have a 3/0x3/0 window that will go in too. the 2nd pic is the concrete footer for the new wall. Just took the forms of it today. After the wall is finished it will all be covered with tin from the replacement of the roofs from the last hail damage.
The last pic is the sliding door all cut up for firewood for next winter. My son is here from CA to help out for a few weeks.
ID:	150647   Click image for larger version
ID:	150648   Click image for larger version
ID:	150649   Click image for larger version
ID:	150650   Click image for larger version
Woodrow Wilson
Old 05-04-2019, 08:02 PM
Sound and looks like a project going on...
I only have folding doors on my shop and at times wish I just had an entry door... but moving big things in and out the big door opening will have to stay for a while until I do an add on or a separate building next to this one...
Is your other door wide enough to get equipment in and out of the shop when you need to ??
Old 05-04-2019, 08:41 PM
I have a 4' homemade door and a 3' standard man door. Seems to get everything done OK.
Woodrow Wilson
Old 05-05-2019, 12:41 AM
Cool cool... Was just curious
Old 05-07-2019, 07:47 PM
Sun came out for a couple hours this afternoon so got the wall all framed up and secured. Got more welding and lag bolts as well as the bottom plate anchor bolts. After that, the OSB, then the window.
ID:	150677   Click image for larger version
Woodrow Wilson
Old 05-10-2019, 08:15 PM
Got the OSB and window installed today. About a week from now I will drill the bottom plate and concrete for the anchor bolts after the concrete has cured a little more. Next will be the tin. I have a large pile of used tin from roof replacement to use on the shop.
Woodrow Wilson
Old 05-10-2019, 08:19 PM
RED caddy's Avatar
Da Chief
good things happen when you capture good help you can lean on...
Old 05-10-2019, 08:30 PM
Woodrow Wilson
Old 05-11-2019, 06:39 PM
First inside upgrade.
Woodrow Wilson
Old 05-11-2019, 07:20 PM
Storage and organizing is good
