  #121
Old 12-31-2018, 01:51 PM
Must feel good to have a solid roof now.
Woodrow Wilson
  #122
Old 12-31-2018, 02:05 PM
Always nice to have the water where you want it, or don’t want it to be!!
  #123
Old 01-02-2019, 07:03 AM
Lu47Dan's Avatar
Lu47Dan Lu47Dan is offline
Connoisseur of Old Iron
Well, the weather forecast is favorable to the tear off and rebuild of the south side of the roof. A little snow but no rain until next Monday.
So I am going to try to get it done, this week.
Dan.
Miller XMT-304 Multiprocess
Miller 10-E Wire Feeder
Hobart AC/DC stick welder
Hobart 175 Mig
Craftsman O/A set
Turbo torch and B-tank
  #124
Old 01-03-2019, 12:37 AM
Hope the weather holds for you!
  #125
Old 01-06-2019, 10:44 AM
Lu47Dan's Avatar
Weather forecast did not hold true, but I was leery of starting the tear off. So I waited. We got rain, and more forecast for this coming Tuesday. After that it is supposed to turn cold for about two weeks, so we will see, if after Tuesday I can start on the south side. Have wood to split and haul today and tomorrow, so I will be busy enough until after Tuesday.
Dan.
Hobart 175 Mig
Craftsman O/A set
  #126
Old 03-24-2019, 05:03 PM
Lu47Dan's Avatar
Okay, the weather forecast is for four dry days, starting tomorrow. So off comes the old roof down to the attic floor (old flat roof), the roof over the boiler room will be removed and a flat ceiling framed over, so the new eave line will be the same as the north side is.
Was going to start today, but there is rain around.
Dan.
Hobart 175 Mig
Craftsman O/A set
  #127
Old 03-25-2019, 06:19 AM
Default shop redo
Dan, you've had nothing but weather and rain delays for quite some time now..seems every time I can get a break outside and get set up,rain again shuts me down too..maybe we need to get together and buy an old circus tent to set up over top of our work areas..no rain delays then..just watch out for the tigers and lions lol
Not Enough Room
  #128
Old 04-02-2019, 05:56 PM
Lu47Dan's Avatar
Bunk, weather still not cooperating......
But the coons are back, I am going to set the live trap tomorrow. Then add somemore patching to the hole in the roof. The dang critters have ripped the hole larger.
Dan.
Hobart 175 Mig
Craftsman O/A set
  #129
Old 12-27-2019, 12:22 AM
Lu47Dan's Avatar
Update, have started tearing off the old roof on the south side of the shop.
Borrowed three pick's ( two 16' & one 12') from my neighbor, have the scaffolding built and have about half the old roof off, as of dark last evening. Plan is to finsh tear off in the morning and start the new framing Saturday morning. Might be able to finish framing by Sunday afternoon.
We will see.
Dan.
Hobart 175 Mig
Craftsman O/A set
  #130
Old 12-27-2019, 12:50 PM
Lu47Dan's Avatar
South side roof of the shop is down to the rafters.
I had decided to modify the roofs pitch by bringing the eaves height up to the level of the old flat roof. This will require some demo of the existing roof structure, about 90% of it.
Have to leave that for tomorrow, as I need to go to work.
Will have to get more lumber in the morning also.
Dan.
Hobart 175 Mig
Craftsman O/A set
