Old 03-05-2013, 11:17 PM
Did you get a manual for your saw? It says not over tighten vice and I know why
Old 03-05-2013, 11:25 PM
justgurn justgurn is offline
I don't know how yours is but mine rear vice swivels and is held by two bolts and if you really reef on the vice screw the rear jaw will move.
I understand now. Mine has 2 set pins in the rear stop. I downloaded the manual and recall reading not ot over tighten.
Old 03-06-2013, 01:01 AM
Originally Posted by justgurn View Post
Now to build a platen for vertical cuts.
I assume you read the part in Judge Bob's saw thread about those little saws being a little bit tippy in the up position?
Old 03-06-2013, 07:33 AM
Thanks I missed that post.
Old 03-06-2013, 07:42 PM
Default Saw goodies
Here are some additions I made for my saw.
1-2 This is a chip brush bracket, Wellsaw wanted a lot of dollars so I
made one. I bought the brushes that are reversible. I think it is
something that you should do.
3-4 I have a dedicated battery screw driver (junk store) that stays on
the saw to run a threaded rod out when cutting short stock.
5 This is a clamp I made for cutting odd shapes without using the vise.
The square slips into the slot and then turned sideways. It works
great but if I made another it t would be a little bit higher. I can I
just get a 3/4" plate under it and it doesn't need to be so long.
ID:	102643   Click image for larger version
ID:	102644   Click image for larger version
ID:	102645   Click image for larger version
ID:	102646   Click image for larger version
Old 03-06-2013, 07:43 PM
Another pic of the clamp
Old 03-06-2013, 09:25 PM
I like the clamp, digr.
Old 03-06-2013, 09:45 PM
Great mods Digr! Thanks for sharing them wih me. I bought the expense blade brush from Wellsaw. Should have fabricated my own but didn't have any ideas at the time. Your clamp stop is a great idea. I could have use it many time with my old saw. I have never drilled and tapped cast before any tricks I should know about? The hold down for short pieces is on my build list.
Old 03-07-2013, 06:48 AM
Digr,
I love the clamp idea.. I'm gonna pilfer it.. did you make the bottom nut adjustable on hold down rod?
_________________
Jennifer
My google+ page
DoALL 36"
Old 03-07-2013, 08:24 AM
Thanks like I say mine is a little on large size
Not a problem tapping cast, its softer than steel
Digr,
The square that slides threw the slot in the table is threaded, just slide it threw and tighten until its crossways. It could be a little longer.
Tags
58b, wellsaws
