Old 10-10-2020, 06:43 PM
camdigger's Avatar
Roving Reporter
Default Lathe TLC
I managed to strip the threads on the two M8 screws that hold the compound to the cross slide on my lathe. After much handwringing and many skull cramps, I took on the job of removing them. Turns out, it is easier than I thought, and much easier on mine than Kieth Fenner's.
Now to hodge up a tee bolt to replace the original. I'm thinking a simple weld buildup of common hardware and a little machine work. Pays to have more than one lathe
Not real impressed with ball oilers. By my count, there are 6 8mm OD ball oilers that should be replaced. Pretty sad, when there are only a dozen on the whole machine. Any suggestions on a Canadian source?
ID:	157971   Click image for larger version
Old 10-10-2020, 08:17 PM
No need for welding with another lathe around, just a little grinding after turning and threading
Old 10-10-2020, 08:54 PM
That cross slide looks suspiciously like the 8 we have in the metal shop at Valley High. (my memory is on a strike at the moment) . :-)
...lew...
Old 10-10-2020, 09:05 PM
Cam, they are called Gits oilers.
Available in Edmonton
Motion Industries has them as well as Guillevin International, the hydraulics dudes.
Old 10-10-2020, 09:22 PM
camdigger's Avatar
Roving Reporter
Neither the Barnes #5 nor the Taig are set up for single point threading, and I don't have a tap and die for the closest SAE thread.
Old 10-10-2020, 09:23 PM
camdigger's Avatar
Roving Reporter
Thanks Gerry! There is a motion industries in Red Deer...
