Old 10-09-2020, 12:59 PM
Cavalry's Avatar
Cavalry Cavalry is offline
Below Wholesale
Default Loader Pin Debacle
A simple job made overly complicated.
I acquired a clapped out wheel loader last year that desperately needs pins and bushings on the bucket pivots. I popped apart what was left and guessed it was 1.5" diameter pins. I originally was going to machine both the pins and bushings but after finding some 1.5" 4140 prehard in my steel rack said I'll buy the bushings and make the pins to save some time and get this thing back together.
All the pin bosses have wear, but i didn't know how much exactly. The pin material I had on hand measures 1.495" which would be great for a 1.500 ID bushing and they were a bit loose in the bosses but acceptable for this pile of shit.
I got a little surprise when the OE bushings arrived and were 1.496 ID" Whoops. I have neither the time or inclination to repair all the bosses and then make or buy 1.490" pins.
The replacement bushings are very hard so reaming/turning is out. with the carbide technology I have. I could anneal and re harden but I have no clue what they are made of exactly and it would likely go bad.
I did just buy a tool post grinder which would make simple work of enlarging the ID of bushings but wont have it until next week and do not know completeness or functionality.
The only other thing I thought of which is kind of a terrible idea is to turn the 1.495 pins 2/3 of the way to 1.490. That way I get one boss that fits kind of good but can still get it in the bushing. Maybe make a collar of shim stock and loctite it in for the loose boss? Its going to be a low hour use machine a couple hundred hours a year would be a lot.
Any other ideas?
Old 10-09-2020, 02:06 PM
Tool post grinder and make the pins 1.490?
Old 10-09-2020, 02:18 PM
If it is just for home use, unless you need super tight tolerances, it probably would be fine to turn 2/3rds of the pin to 1.490”. As long as you can get grease into it, you probably will not notice it too much.
But, it all depends on how fine of bucket control you need for your application.
Old 10-09-2020, 02:21 PM
A box tool in the lathe would take those pins right down in one pass, hold size, and leave a very good finish.
Old 10-09-2020, 03:14 PM
Tool post, do it wright and forget it IMHO
Old 10-09-2020, 03:40 PM
Cavalry's Avatar
Below Wholesale
I really don't want undersized (well correct size) pins as the bosses are worn. the 1.495 pin material fits reasonably well in the worn bosses. Do do it "more correctly" I should ream the bosses out to a uniform size like 1.500, grind the bushings to 1.505 and make new pins.
Old 10-09-2020, 03:44 PM
Cavalry's Avatar
Below Wholesale
The purpose of this machine was to save my Kubota MX5100 tractor. Digging into gravel banks, pushing snow, killing vegitation. I refer to the loader as the hatchet and the tractor as the scalpel
