Old 10-08-2020, 11:40 AM
OldRedFord's Avatar
Kibble King
Default 10 horsepower rotary phase converter
Im building a 10 horsepower rotary phase converter. I've already got a potential relay and a motor contactor rated for 10 hp at 240 volts three phase.
I've got a 250 uf start capaciter and some terminal strips on the way. Should be here Saturday.
After I get a motor I'll get some volt readings and figure out what I need to balance the output.
I've already got a enclosure to house the relays and capacitors.
Where's a good diagram to wire all this up?
I assume I need a double pole single throw switch to activate the motor relay. It has a 220v coil.
Tim
Old 10-08-2020, 07:39 PM
OldRedFord's Avatar
Kibble King
Working on a layout. Found a 120v coil Allen Bradley relay for the start capaciter.
Tim
Old 10-08-2020, 08:20 PM
460 Delta's Avatar
460 Delta 460 Delta is offline
That Packard DP contactor is not really up to the task. It’ll last for a while, but will fail fairly soon. DP’s are made for easy, fast starting loads like A/C compressors and deep well pumps. You really need a NEMA size 2 starter in your favorite brand supported locally.
Perfection is the enemy of good enough.
Old 10-08-2020, 08:49 PM
OldRedFord's Avatar
Kibble King
Would a lighting contactor work? Got one of thise laying around. Three pole 60 amp rating.
Tim
Old 10-08-2020, 09:04 PM
Wiring schematics
Old 10-08-2020, 09:27 PM
Scotts Scotts is offline
You got enough of a start there Red use what you have and learn.
Yes those contactors won’t last long. For what you are doing it will last a while.
At the rate you are picking up equipment you should run into a box of old Allen Bradley stuff that will only last till your kids get rid of it.
Digr has linked you to a good start on info.
I have a 3 wire start stop on mine with a timer that drops out the cap.
Look up Cutters info on his phase converter it helped me quite a bit.
Old 10-08-2020, 11:25 PM
OldRedFord's Avatar
Kibble King
I forgot a had a back panel with various electrical components hiding under a tarp at my house.
From it I pulled a section of din rail, the Allen Bradley relay and wire terminals and fuse holders you see.
Did some more digging and found a 240v primary and 120v secondary control transformer. Also Allen Bradley.
The coil on the contactor is 220 while the relay coil is 120.
Tim
Old 10-09-2020, 04:21 AM
460 Delta's Avatar
Yeah a lighting contactor will work, but you ought to have a overload relay on it. I've seen many that didn't have them though.
Old 10-10-2020, 02:50 PM
OldRedFord's Avatar
Kibble King
Got my hands on a 10 horse motor for the idler. It's 240/480 but only one set of leads coming out and can't be rewired. Let's hope it's 240.
Tim
Old 10-10-2020, 03:05 PM
460 Delta's Avatar
The tag should have the voltage XXX out, but many motor shops don't do that. If it's a 3 lead, most likely it's for 460 now, especially if the leads are 14awg.
