Old 10-08-2020, 10:51 AM
Default Strange Counterbore
It secures in a tapered spindle but I can’t imagine what looks to be an adjusting nut on the end is for. Any of you fellows know?
Old 10-08-2020, 11:03 AM
Interchangeable pilot?
Old 10-08-2020, 12:08 PM
I believe it's for the eject part of the Morse taper.
Old 10-08-2020, 02:30 PM
LKeithR LKeithR is online now
...Interchangeable pilot?
I doubt it. Interchangeable pilots are usually held in with a simple setscrew in the body. If that part sticking out the end were meant to retain the pilot then the counter bore would have to be hollow and the pilot would be threaded. Highly unlikely.
That would normally only require a short chunky little stub. What you see there is pretty long and spindly. If the counterbore is threaded then that piece sticking out might be the remains of some kind of jury-rigged drawbar...
Old 10-12-2020, 12:33 PM
Will I Am Will I Am is offline
Maybe a Browne & Sharpe taper with a broken draw bar?
Cheers Will
