Old 10-09-2020, 10:51 AM
The numbers I found are
MR
506
8848
Searching "diode MR506"
comes up with a 3-amp 600-volt diode.
Like I said if you buy new get the higher voltage range 800, 1000......
I generally look for the 1000 volt. for general purpose diodes/rectifiers.
just a note
If we talk "Zener diodes" then the voltage has to be exact.
"Zener" diodes are a class of diode for voltage regulation, also have a different schematic symbol.
Old 10-11-2020, 01:26 AM
Gadgeteer's Avatar
For future reference...
Diodes In Parallel. If the load current is greater than the current rating of a single diode, then two or more diodes can be connected in parallel to achieve a higher forward current rating. Diodes connection in parallel do not share the current equally due to different forward bias characteristics.
Old 10-12-2020, 05:44 PM
It's better if you get them from the same production run, AFIK. Diodes can be weird, Zener diodes and transient-voltage-suppression (TVS) diodes and all that.
